Old 05-22-2015, 07:36 PM   #1
Rear window 295rst Crusader
We've had a lot of rain this year along with cold. Rear window always has water in the track on the non opening side. Thought was condensation with heater use but since it is in the driveway now water accumulates during every rain. Seal appears good, cannot find any cracks.
Any idea where this water may be leaking in from? Any other Crusader folks have this issue?
2014 Crusader, 295rst.
rarterbury is offline   Reply With Quote
Old 05-22-2015, 07:50 PM   #2
heavynlori's Avatar
Are there weep holes on that side?
heavynlori is online now   Reply With Quote
Old 05-22-2015, 11:43 PM   #3
Great question will look in the morning. I believe I saw a couple of rubber pieces but did not try to remove.
Old 05-23-2015, 08:59 AM   #4
Great tip, pulled the four rubber spacers on the outside of window drained she did. Thanks for the help.
Old 05-23-2015, 08:18 PM   #5
Drains
Caution on removing the rubbers. Are they actual full plugs or just dirty drains. Usually the back windows and the bedroom side windows have rubber or plastic deflectors installed to deflect water in vacuum pressure areas from being forced inside. We had a customer a while back with water leaks in his rear window while pulling in the rain. Took us a while but after we installed the drain deflectors , it eliminated his problem.
hillsdaletc is offline   Reply With Quote
295, crusader
