Old 02-24-2016, 12:30 PM   #1
Removal of Motor on Lippert Awning
I need to remove the motor from my Lippert Solera awning. Either a gear has a bad tooth or their is a dead spot in the motor. Anyway, is it possible to remove the motor without the awning unwinding or creating some other unintended consequence?
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
Teamfour is offline   Reply With Quote
Old 02-24-2016, 01:13 PM   #2
rracer5's Avatar
I'm not familiar with Lipperts awning but, I do have experience with Dometic. Your awning may be "pre-loaded" to assist it retract. There may/should be a process to "pin" the roller so when you disengage the motor the spring doesn't unwind.
Solera® Power Awning
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
awning
