Old 09-29-2015, 04:34 PM   #1
Replace Storage Compartment Door and Frame
Through a dumb move, I really crimped the frame of a storage compartment door. Are the only things holding this in place the twin screws on the top and the bottom? Does the frame and door come out as a unit if I remove the screws? The compartment is by the front door of the passenger side of a 2015 Rockwood Roo 23IKSS. Any help would be appreciated.
mlawler506 is offline   Reply With Quote
Old 10-20-2016, 06:09 PM   #2
I am in the same predicament. I have a storage compartment door that I severely damaged. I ordered a new door from FR. Now I find myself wondering what to use, besides screws, to seal the frame. Any advice would be greatly appreciated.
2016 Rockwood Windjammer v-nose.
Chef
Students do not care what you know until they know that you care.
Chef is offline   Reply With Quote
Old 10-23-2016, 08:55 PM   #3
Two screws and some tough caulk hold the unit in place. In replacing the unit, you need to use some RV caulk. That is all that I did. Make sure that you push the unit in to snug it to minimize how much it sticks out.
Old 10-24-2016, 06:42 AM   #4
Head Rambler
The screws sandwich the frame pieces together, and the factory normally uses butyl tape to seal the outside frame to the RV siding. Once you remove the screws you'll have to gently pry around the outer frame to loose it from the tape. You can then remove the tape/sealant residue.
You can get butyl tape at most RV stores, but you could also use polyurethane caulking to seal the frame to the RV, but be aware that if you use that, you'll have a real problem getting it off ever again.
Gotta go campin!
Old 10-24-2016, 07:09 AM   #5
Herk7769's Avatar
1/2 inch butyl tape is cheap and plentiful at any RV store or online.
With Amazon's 2 day free shipping, you can order it here.
Once you have the frame reset, just run around the frame lightly with a razor knife to cut off the extruded tape.
https://www.amazon.com/Hengs-Industr...rds=butyl+tape
HAM CALLSIGN - KC3FFW
Old 10-24-2016, 10:33 AM   #6
Smile
Thank you very much everyone. I'll post a picture when I'm done.
That is unless I goof it up.
Chef
Old 10-24-2016, 04:24 PM   #7
Head Rambler
Post 2 if you goof up!
Gotta go campin!
door, frame, storage
