Old 07-20-2015, 02:45 PM   #1
Replacement Storage Locks
Hi there..
I'm looking to replace all of the storage locks on our 5th wheel Shockwave trailer. It came with the basic locks that have a thin rubber washer under it that doesn't last long at all since the door is somewhat soft. I've seen other rigs that the washer is a thin flat washer of some kind that is must sturdier than the rubber pieces.
Anyone any recommendations for a better lock? I know it won't keep everyone out, but it may be slightly better than the common locks they install at the factory and actually allow me to tighten them down so they don't move around much.
Thanks for any suggestions anyone might have for me..
Allistah is offline   Reply With Quote
Old 07-20-2015, 03:08 PM   #2
mark0224's Avatar
RVLocksAndMore | RV Locks | RV Keys | Fastec FIC Locks and Keys they will even key them so they are the same as your door key if you can give them the door key code.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
replacement, storage, lock
