Old 10-08-2019, 03:33 PM   #1
Replacement Window Suggestions
I had the inside pane of a front window of my 2019 Cedar Creek 40CCK break due to heat. Forest River has changed the window design in 2020 models to be 50/50 split vs the 75/25 split on the 2019 models. I reached out a dealer close to my home as I purchased this RV in a different state and after research on their end I was told the 2019 version of the window with the 75/25 split is no longer available.
I have also reached out to the dealer where I purchased the RV and was told I might have luck contacting the window manufacturer LCI directly.
Anyone have suggestions on other possible options/vendors to purchase a replacement window for the 2019 40cck that would have the 75/25 split? I have tried to attach photo to this post. Thanks for any suggestions
Kirbails is offline   Reply With Quote
Old 10-09-2019, 01:33 PM   #2
Head Rambler
Do you have overall measurements for that window?
www.easyrvwindows.com and www.pellandent.com Are a couple of places that should have what you need.
If the frame isn't hurt, you should be able to take it to a glass dealer and have just the glass replaced.
Gotta go campin!
replacement, window
