Old 07-10-2012, 10:31 AM   #1
Replacing Awning Fabric
Has anyone replaced thier awning fabric. We suffered about an 18" tear in our awning on the past trip. It is a Dometic 12' electric awning.
How easy is it to slide the fabric off the roller and the RV roof guide rail?
Thanks in advance
2011 SunSeeker 3170DS
hunt247 is offline   Reply With Quote
Old 07-10-2012, 10:44 AM   #2
Dovetail's Avatar
not from personal experience, but a camping buddy changed out his and said it was pretty easy
Rick and Linda, Lindale, TX
2011 Flagstaff 8528 CKSS
2006 F350 SW
Camping nights 2013: 130
Camping nights 2014: 17
Dovetail is offline   Reply With Quote
Old 07-10-2012, 11:04 AM   #3
Thanks in advance
Not a real hard job, but you will need a helper and most important BE CAREFUL, the torsion springs are extremely dangerous if not handled correctly.
File Type: pdf Awning material replacement instructions.pdf (292.8 KB, 851 views)
Old 07-10-2012, 11:15 AM   #4
Someone posted a great tutorial about changing awning fabric I think it was on FRF not that long ago
jalvin is offline   Reply With Quote
Old 07-11-2012, 07:16 AM   #5
would an electric awning have torsion springs?
Delaware is offline   Reply With Quote
Old 07-11-2012, 07:54 AM   #6
Yes, the torsion spring is in the opposite end from the motor. When we straightened the tube on ours, we had the awning deployed about 6-8" from the camper side. It allows for getting a pair of Vise Grips on the end and turning it and relieves some of the pressure on the spring.
Old 07-11-2012, 02:49 PM   #7
There is actually a hole in the end cap, when positioned horizontal, you can get a nail or a cotter pin through to lock the spring. This should be done before you take anything loose from the camper. There are also one or two screws in the rail on the camper that keep the fabric from sliding, these have to come out. Use a Sharpie to mark which grooves the fabric is in before you remove it, and put the new fabric in the same grooves. Use steel pop rivets in the end cap you remove, not aluminum ones.
It can be done, just takes a day and a few friends.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 07-12-2012, 06:19 AM   #8
Thanks everyone. Windrider, that tip is very helpful. I think I am ready to get the fabric and start the repair now.
Old 07-12-2012, 07:05 AM   #9
KyDan's Avatar
See this thread and video of how it's done.
http://www.forestriverforums.com/for...eek-22185.html
Gather a few friends and the tools suggested and go for it.
Good luck!
Let us know how it goes.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 07-27-2012, 02:17 PM   #10
We replaced ours very easily, and very carefully. But we had to drill opening in the end of the cap to avoid the tension spring. It worked fine and we just put silicone over the drilled end to keep it in place. Very easy
judidon is offline   Reply With Quote
awning
