Old 08-28-2012, 08:23 PM   #11
Timex's Avatar
Duct tape!!!
Timex is offline   Reply With Quote
Old 08-28-2012, 08:57 PM   #12
We had the same thing happen, and simply replaced the screws with bigger ones that also had larger heads. Now they hold tight. The teeny screws the factory used are simply too small, and of course the installers probably over-tightened them, stripping the holes in the door.
bakken is offline   Reply With Quote
Old 08-29-2012, 06:12 AM   #13
Herk7769's Avatar
Originally Posted by MilCop4523 View Post
Glad Herk was talking about the screen door and not Dw pounding sand. All I could think of was That guy in the 80's with the wooden maul pounding watermelons and everything else
That was "Gallagher" with his Smash-O-Matic
HAM CALLSIGN - KC3FFW
Old 08-29-2012, 10:56 PM   #14
vasnipe's Avatar
Ahhhh! Saw him in 1982 here in little old Roanoke, VA
The Sledge-O-Matic!
It slices, it dices, and it even makes julienne fries if you crack that sum-b juuuust right!
Gallagher - SLEDGE-O-MATIC!!
2006 Sunseeker 3100SS/LTD
2008 Smart Passion Cabriolet TOAD
1986 Honda Helix (Original owner)
vasnipe is offline   Reply With Quote
Old 08-29-2012, 11:50 PM   #15
Just a member
kandl's Avatar
Ditto - same issue, same fix. Better than new.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 08-30-2012, 06:06 AM   #16
Herk7769's Avatar
The Sledge-O-Matic!
That's right! Sledge-o-matic
Old 08-30-2012, 06:14 AM   #17
MilCop4523's Avatar
I noticed my screen door is rubbing tight upon closing. The wee little screws are being swaped out for some bolts, lock washers and nuts with some locktite.
09 Sundance 31.5 XLT Bunkhouse
17 Greywolf 22rr Toy Hauler
and
The new toy hauler - 2016 Ford F150 Supercrew XTR ECOBOOST.
MilCop4523 is offline   Reply With Quote
Old 08-30-2012, 09:12 AM   #18
Ours wasn't making connection, so I unscrewed it, moved the latch over (within tht factory adjustment) and tightened. At that point, the latch rubbed the frame. So I moved it back to the original position, inserted a screwdriver in the slot of the door frame and brought it out a tic. Holds and fits fine now.
In your case, I'd just use larger screws...or rivets....and tell the wife to either like the way it looks or fix it herself.
2006 Ram 2500 CTD
2011 Sabre 31RLDS
awjoker is offline   Reply With Quote
Old 08-30-2012, 09:22 AM   #19
Mark and Linda's Avatar
Mine was doing the same thing as yours....adjusted it on the last camping trip out.
2009 Palomino Puma 25RS
2007 Chevrolet Silverado
Prodigy P2 Brake Controller
Mark and Linda is offline   Reply With Quote
Old 08-30-2012, 09:27 AM   #20
My sentiments exactly, that's why I said pop rivet it and tell DW to go pound sand.
