Old 07-26-2019, 08:47 AM   #1
Screen door latched in 2 places
This is my first RV so Iím not sure if this is normal... My screen door has a 2-way spring latch that automatically connects it to both the main door, and to the frame. This serves the purpose of keeping the screen door out of the way. However, it becomes a problem when Iím outside of the RV, with both doors closed; When I attempt to open the door, I have to pull it extra hard to force it apart from the screen door.
The problem is that the main doorís latch disconnects it from the frame only, but not from the screen door, leaving it effectively tethered weakly to the frame by the screen doorís 2-way latch. The latter is not accessible from the outside when the main door is closed, forcing me to yank it separate the two, and it feels like Iím doing damage to the screen door latch every time I do that.
Is that normal?
Shanksworthy is offline   Reply With Quote
Old 07-26-2019, 08:56 AM   #2
No that is not normal.
You need to adjust the keeper (the part on the main door) lower. When it is adjusted properly it will keep the screen door latch retracted just enough as to not catch on the striker when both are closed.
Very simple adjustment.
2017.5 Forester 3051S
2016 Honda Accord
Steve-W is offline   Reply With Quote
Old 07-26-2019, 09:23 AM   #3
Exactly what Steve said. I just made some adjustments to mine a few days ago and it took me about 5 minutes. I didn't like how hard the screen door had to be pushed to latch onto the trailer door. I had to find the happy medium between the screen door latching to the trailer door and the trailer frame. It doesn't take long and all you need is a screwdriver.
Draggo is offline   Reply With Quote
Old 07-26-2019, 01:46 PM   #4
Ah, so the keeper on the main door overrides the part on the door frame? That makes sense. Iíll give it a try. Thanks!
Old 07-29-2019, 07:40 AM   #5
DouglasReid's Avatar
Both the prior posters are correct. Let us now how it works for you.
2012 Wildcat Sterling 32RL, Gladiator Qr35 ST235/85R16 Load rating G, TST 507 TPMS w/ Flow-thru Sensors & Repeater, Reese Sidewinder 16K Pin Box
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 07-29-2019, 11:38 PM   #6
I havenít had a chance yet, but Iíll try this weekend and let you know.
Old 07-30-2019, 12:26 AM   #7
And when you finally get tired of that latch, do what I did and get rid of it completely. I just copied what this guy did:
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is online now   Reply With Quote
Old 08-12-2019, 08:17 AM   #8
I meant to mention, the suggestion of lowering the keep worked. Thanks for that.
However, the spring on our latch keeps giving out. It was defective when we received the unit and we had it replaced under warranty, and it gave out again a couple days ago. When I opened it up to have a look at the spring, it just crumbled. So the dealership give me a whole new latch assembly. Iíve installed the new one and weíll see how that goes. Worst case, Iíll throw the thing out entirely and go with the magnets.
door
