Old 06-28-2014, 10:05 AM   #1
RedStick's Avatar
Screen Door - the screen detached from the door frame.
Any easy way in securing the screen back in the groove by chance?
2013 Rockwood Roo 23ss
2012 F150 Ecoboost
Camped for 12 nights in 2015 - too many cancellations
Camped for 25 nights in 2014!
Camped for 24 nights in 2013!
RedStick is offline   Reply With Quote
Old 06-28-2014, 10:10 AM   #2
Ford Idaho's Avatar
What was holding the screen in to start with?
Old 06-28-2014, 10:18 AM   #3
RedStick's Avatar
It looks like the screen is (or should be) seated between a rubber gasket.
I really need bifocals ;(.
2012 F150 Ecoboost
Old 06-28-2014, 10:27 AM   #4
Ford Idaho's Avatar
http://cutcaster.com/photo/800993392...n-repair-tool/
This is what you might need to get.
If you look in one of the corners you will see a joint where the section of rubber "rope" meets.
The "rope" will pull right out if you use a small screw driver to lift it enough to grab a hold of.
Here are several videos on the topic.
https://www.google.com/search?q=wind...&bih=690&dpr=1
Old 06-28-2014, 07:54 PM   #5
RedStick's Avatar
Thanks - looks like I've got a project to look forward to.
2012 F150 Ecoboost
Old 06-29-2014, 04:33 AM   #6
a few tips
Sometimes the screen will push right back into place and the spline will press fit into that groove using the spline tool. If it's a small area, a butter knife or other blunt instrument will work. Wipe a little WD-40 or similar on the spline first. Often the rubber spline has dried and shrunk too much to be effective. If you replace the whole screen, the biggest problem will be to avoid deforming the frame. As the screen is pushed in the groove with the spline tool it will tend to pull the frame (especially the sides) inward. I would clamp the frame to the bench first in order to avoid this. The screen should be at least an inch bigger than the frame on all sides. Seat the screen with the tool and follow by seating the lubricated spline in place. It's not a difficult repair but takes some time. And be careful not to cut the screen with the tool.
You can purchase the screen and spline at any home improvement store.
2011 Sabre Silhouette 260BHS
2006 F-250 6.OL
tinkerreknit is offline   Reply With Quote
door, frame
