03-23-2018, 11:16 AM
Always Learning
Screwing into door and camper wall
I'm going to install a magnetic door catch for our doors. Right now, they have struts that keep the door from opening more than 90-degrees. It's silly as there is nothing in the way.
What do I need to know about screwing into the door and keeping it all water tight?
03-23-2018, 11:28 AM
That's exactly what I used on our interior doors. Not sure how they would hold outside in a breeze.
03-23-2018, 11:29 AM
Keeping things water tight is easy. Apply some sealer/caulk to the screw before putting it into a pre-drilled hole.
Hardest part is making sure you have enough structural strength to support whatever you are mounting. Depending on the door/camper wall, you usually have a thin material on the outside, some thin material on the inside, and some foam (just like the formed styrofoam used to protect edges and corners on TV sets when you unbox them) between the two surfaces.
If you can't find a structural member to firmly secure your door catch to it might be a good idea to use a piece of backer material on the inside. A piece of 3/16" aluminum plate pre-drilled to the bolt pattern of your device. Drill through the wall/door, apply some sealer to the bottom of the device, insert machine screws (preferably stainless) through the wall, then using a sealer/adhesive, apply enough to coat the side of the backer plate that will face the inner surface of wall/door. The plate should be twice to 3 times the area of the outside device. Put backer plate over screws and secure with nuts. Tighten until it just starts to compress he sandwich but not to the point you can see "dips". The backer plate will distribute any leverage forces on the door or wall which should keep the device from loosening or breaking out a piece of wall/door.
May seem like overkill but it may be the only way to keep a door that slams agains the stop/catch from breaking a hole in the side of your camper. It of course will depend on how strong your camper door/wall is so act accordingly. Like I said at first, sealing out water is the easy part
03-23-2018, 11:34 AM
Always Learning
I actually think they'll do OK in the breeze. But what I didn't think of is how they'll hold up to the elements....
Though, it does claim to be stainless steel.
03-23-2018, 11:37 AM
Always Learning
Good info. Thanks, Titanic.
03-23-2018, 11:46 AM
Be sure your door hinges are designed to go 180 degrees. Are any vents gonna be behind the opened doors? Light fixtures?
03-23-2018, 11:52 AM
Always Learning
Good point on the hinge. I'll pop the strut off and will check how the door goes.
No other obstructions.
03-23-2018, 11:58 AM
Where do you get these. I have had the wind catch my 90 degree door twice and break the strut. I agree... it is stupid to have a door that goes only 90 degrees.
03-23-2018, 12:15 PM
Rather than a strut I almost would prefer the old screen door chain and shock absorbing spring method.
Attached at the outer corner of the door and at corner of door frame maximizes holding strength if the wind catches the door.
To "beautify" the chain/spring, wrap it in a layer of felt formed into a tube.
A simple bungee cord for a "Hold open" device.
As you might notice, I'm more into function than beauty. If the door is being held open at 90 degrees with a bungee cord that's a great place to hang a towel or swimsuit too.
03-23-2018, 12:17 PM
My door was fairly sturdy, but was filled with foam. I ended up putting some liquid nails on the back and using screws to hold it while the glue dried, then just a small bead off silicone around the outside. I had considered the backer plate option, but it just seemed like over kill and I can’t stand the looks of it. This was on our old camper, had it 4 yrs and never had a problem
03-23-2018, 12:31 PM
Good idea. I'm going to CW in Portland today if it stops snowing and explore some options. I think i like the chain and spring too. Maybe put a catch on the fully open part and unhook the chain if i want the door to stay open
03-23-2018, 01:44 PM
What is the reason for the 90 degrees hold open?
03-23-2018, 01:47 PM
Always Learning
My indoor one came from Home Depot.
This particular one is on Amazon. I don't think HD had all black ones which is what I want due to coloring of the door and lower panel:
https://www.amazon.com/MATEE-Stainle...dp/B074VQVT3K/
03-23-2018, 01:49 PM
Always Learning
¯\_(ツ)_/¯
03-23-2018, 01:59 PM
Magnetic door latch
We had our dealer install one of these outside our Rockwood 8299 5th wheel. It is near the clasp that holds the door from closing in a breeze. Our door did open all the way, though before that. The magnet holds securely so far and all we have to do is reach around and grab the door to close it. That in itself is very useful if it starts to rain.
03-23-2018, 07:43 PM
ARLO
I would also use some 3M commercial two sided adhesive tape (red plastic peel off).
03-23-2018, 08:40 PM
All exterior penetrations are usually sealed with butyl. It squeezes into spaces to exclude water and excess can be easily cleaned away.
Travel safe
2019 Ford F-350 Super Duty CC Dually 6.7 Diesel
2011 Cedar Creek 36CKTS Touring Edition
I Catch Fish......What is your SuperPower?
03-23-2018, 08:46 PM
BTW, in my opinion, silicone has NO usefulness on/in/near an RV......YMMV.
TRavel safe
03-23-2018, 09:38 PM
03-23-2018, 09:51 PM
On mine the wind took the original setup off the door pulling the screws out. I ended up taking a white powered coated plate (the ones that come inside electric panels) and I used some double sided tape on the back and remounted the clasp part to the plate on the door then sealed around the plate with Dicor been on door since and no more problems. That double sided tape is really great.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
