Old 04-15-2019, 04:47 PM   #1
Slam Latches On Cargo Doors
I am continually having trouble getting my cargo doors to close. I have to lift the handles on the slam latch in order for the door to close. If I let it slam shut, it won't latch. What is a good lube to spray into the handles so the latches will work on their own?
Thanks.
John
2014 Dynamax Trilogy 3850RL - South Hampton Interior, Full Body Paint (Black / Silver / White), MOR/ryde Independent Suspension, MOR/ryde Disc Brakes, ONAN 5500 Generator, Progressive Industries HW50C w/Dual Display, Winegard HD Dish w/DirecTV, Washer & Dryer, iSprings 7-stage Reverse Osmosis Water Filter, Trail-Air Flex Air Pin Box, Third AC installed, AC Voltage/Amp Meters, DC Amp Meter, Garnett See Level Tank Sensors, TST 507 TPMS
Retired USAF - Full Timers!
John Hagen is offline   Reply With Quote
Old 04-15-2019, 05:35 PM   #2
Witch Doctor's Avatar
Thanks.
John
It might not be the latches, eye lube them with anything like WD40, but check your weather seals, I found that stopped mine, corrected that and it's okay now.
Coachmen M/H
Concord
2018 / 300 DSC
Old 04-15-2019, 07:21 PM   #3
It's not the seals. I apply lube to the internal latches by spraying 3-in-1 and that makes them work for about a month. Then it's back to the same problem.
Thanks for the suggestion!
Old 04-17-2019, 08:48 PM   #4
Gosh my 2019 Dynaquest cargo doors will only open about 75% ! Has anyone else having this problem?
Abeís Dynaquest XL on Order
Toads-jeep jk- Ford F-150-Ford edge
Carnesville Ga
Abe padgett is offline   Reply With Quote
Old 04-17-2019, 09:32 PM   #5
Mine are the same. I use silicone spray on them and the main door latch.
2016 RAM 3500 DRW 4x4 LB LoneStar Edition, w/Timbrens, Andersen Ultimate 2, Swift Hitch SH04 WiFi Backup/Rear View Camera
2018 Chaparral 360IBL w/Tireminder SMART TPMS, Furrion Wireless Observation System, Progressive EMS-HW50C
Prior Rig: 2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is offline   Reply With Quote
Old 04-17-2019, 10:05 PM   #6
NMWildcat's Avatar
Same experience with my slam latches. Doesn't matter what I lubricate them with, it only lasts a month or so until I have to reapply. I suspect it is due to the relative openness of the latch mechanism.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
cargo, door
