Old 01-13-2014, 11:00 PM   #21
Infractee
Originally Posted by puff View Post
Yes, I have thought about this and others of a tube or ? or ? My only problem is that I get some high winds and the slide needs to come in. If I have all this stuff under the topper on the slide well it would all have to come down first. My my ideal choice.
Ours have rode out some hellacious winds, storms and severe weather, before the deflappers they made a lot of noise, once installed never had any more problems, never saw a need to bring the slides in that is for sure. I agree tho if some sort of emergency it would be a bit of a pain in the arse.
RhoZeta is offline   Reply With Quote
Old 01-14-2014, 11:02 AM   #22
puff's Avatar
Well I live a stones throw away from open ocean. We regularly get S.E. winds that are 60 - 80km/h (40-50mph) more so in the winter. 2 years ago we hit 137km/h 85 miles an hour...you would pull your slide in too..!
My topper are starting to tear at the seams and or where the fabric must have been weak. All I am saying is that if you encounter strong winds on a regular bases and are not close to the trees...leave the topper off. y .02 worth.
Glen & Robyn (A.K.A. Puff & Crickit) Full Timers..
2006 F350 6.0 with 3.73 gears, 4X4, Extra-Cab Long Box, Oil/Tranny/P.S. Coolers. Coolant filter. SCT Livewire.
2011 Cedar Creek 36RE, Auto levelers + too much to list..!
puff is offline   Reply With Quote
Old 01-14-2014, 11:12 AM   #23
I have toppers on all my slides and wouldn't be without them, makes close-ups a breeze.
One question, is there a way to tighten up one end if they are not equally tight on both ends? I find one end sags a little so I get a little bit of ponding there instead of it running off.
Kemosabi
Kemosabi is offline   Reply With Quote
Old 01-14-2014, 11:15 AM   #24
Fulltime family RVer
Kemosabi, I found this on another thread:
http://www.rvtechlibrary.com/exterior/AE_topper.pdf
Old 01-14-2014, 12:02 PM   #25
puff's Avatar
To my knowledge there is no way to tighten up one end. That means your topper has been cut wrong or installed wrong. Is it bent..? Pooling or puddling in the middle is very common this does not help the ends or the middle from looking even either..!
Old 01-15-2014, 10:13 PM   #26
Infractee
I could see where being near water with a constant wind blowing would be a PITA! I guess with all that wind you would not need awnings anyway as the wind just blows the tops of the slides clean anyway!
Old 01-16-2014, 07:40 AM   #27
Thanks Puff for the document. Since it does mention 13 turns on both ends of the roller attachment arms i suspect that perhaps like mentioned it may have been installed crooked or taped to the roll crooked but one extra turn on the loose end may take up the slack. It's not to bad so I will decide if I try it or not depending if I see any issues starting from it. The ponding right now is only about 12"x6" near the one end so not to bad.
Thanks again for the help.
Again I wouldn't be without these awnings on my slides. The remain as new, the gaskets stay clean and when I closed last fall I whipped the gastets and rubber covers with the gasket conditioner to keep things in good condition.
Kemosabi
Old 01-16-2014, 07:51 AM   #28
Mikegjax's Avatar
Without them all of the debris can end up inside your unit. A must have IMO.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 01-16-2014, 08:06 AM   #29
Brother Les's Avatar
I have camped in every type of environment and have almost always had something stick to my awning canopy. Leaves, twigs, bugs, moss. It is very rare that I do not have to sweep off my canopy as I roll it up. The point of this thread is to have a cover (awning) over the slide-outs so when you pull the slide out in you will not be dragging leaves, twigs, bug, moss into the camper and mess up your seals, etc. I would assume that you should check the top of your slide for debris before you retract it, awning or not. 'Stuff' at one time or another will blow in there. This can be seen by all of the 'talk' about the wind factor on this thread. Does not 'stuff' stick to your slide out awnings that need to be swept off? If you have no awnings on your slide-outs, care should be taken to clean off the top of the slide-out. If you do have awnings on your slide-outs, these also should be cleaned off as they are retracted in.
Brother Les
Old 01-16-2014, 08:25 AM   #30
Cleanout as with anything is important both on and under the awning, or at least check then first. I very seldom have debris under my awning and when I do I use a light duty pushbroom head screwed onto my extendable pole handle (that I use for window and trailer cleaning usually with my cleaning brush/squeegy head). The light duty 24" push broom head goes in nice and pushes all the dirt and dust outprior to closing. also works well for an annual wet scrub so I don't have to detach the awning.
Kemosabi
awning, slide
