Old 12-13-2012, 08:00 PM   #1
Slide awning replacement
I have a 2012 Sunseeker and I need to replace the bedroom slideout awning. Does any1 know who the manufacturer is for the original awning?
retired757pilot is offline   Reply With Quote
Old 12-13-2012, 08:43 PM   #2
Dave_Monica's Avatar
Welcome to the forum!
Did you get a sheet in with your paperwork on delivery which lists all the componenets and serial numbers of the equipment installed on your camper? The slide topper should be listed there.
There's no tag/label on the existing topper or mounting hardware?
Dave
Old 12-13-2012, 08:59 PM   #3
Thanks for the tip Dave. I'll check the paper work.
Old 01-21-2013, 06:16 PM   #4
Completely unroll the slide awning. There "should be" a tag mounted on the housing for the springs, etc. with information on it. From experience: Getting into a position to read this information--well, , ,
Thurman is offline   Reply With Quote
Old 01-21-2013, 07:16 PM   #5
Herk7769's Avatar
Replacing the awning does not appear overly complicated and have seen a pair of "good old boys" with a six pack of Bud do the job in an hour or so.
Here is a sample of how it is done (your awning SHOULD be similar)
File Type: pdf Dometic Slide Topper Service Instructions.pdf (892.8 KB, 19 views)
HAM CALLSIGN - KC3FFW
Old 01-21-2013, 07:37 PM   #6
caper's Avatar
Tough Tops in Yuma Arizona make a great slide topper. It is a heavier fabric then the fabric supplied from the original manufacturer. I helped a fellow RVer replace 3 on a MH last year. It took about 1 hr. / slide and we had our 6 pack afterwards.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
awning
