Old 10-18-2014, 12:27 PM   #1
Slide Stopper!
After a 8 week trip with (Little/No) Issues we arrive Home and open the Slide (Almost!). It ripped the steel hinges into and the (TINY/SHORT)screws in the (Plood/Paper covered particle board)! stayed in ! Most of the time these are the wood screws that fall out on their own! Door is Perfect! Hinges are DOA! Little wood putty and stain on the (Plood )area! Ordered the (Self closing Hinges) to put on all the Doors! Youroo!!
Old 10-18-2014, 12:30 PM   #2
Pics. Youroo!!
ID:	64923   Click image for larger version
ID:	64924   Click image for larger version
Old 10-18-2014, 12:41 PM   #3
Plain Old Member
Had the same thing happen this summer, and like you the door was salvaged, hinges not so much. Luckily our "Plood" was not damaged so bad, and the new hinge covered up the battle scars. Easy fix, but still aggravates the crap out of me.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 10-18-2014, 01:49 PM   #4
B and B's Avatar
I had the wood moulding come off the slide a but as the lazboy chair moved forward and the handle caught it when opening. We came back on I69 from Goshen, just pounded it back on. Now i check the slide when going out after travel. We hit i69 on Wednesday again for a short jaunt to Frankenmeuth.
B and B is online now   Reply With Quote
slide
