Old 05-17-2018, 08:04 PM   #1
Slide topper
Today we were returning home with a 30mph side wind into the drivers side. A gust got under the slide topper and caused it to billow some.Not a whole lot probably about 8 inches or so.. Made a lot of noise. I found a place to stop and put the affected side down wind. Got on the roof and DW was inside running controls, ran the slide out and straightened the material out.. Installed a screwdriver in a hole in the end of the roller tube secured it and tightened the fabric?. Question is,can I make this awning tighter by just winding it up? I plan to get some quality topper cover material to replace the CHEAP stuff up there. Maybe someone has come up with a way to keep this from happening. Any and all comments welcome except the mean ones..Thanks for all!
2017 Georgetown 329S
Toad 2015 Toyota Tacoma
Tbonz is offline   Reply With Quote
Old 05-17-2018, 08:10 PM   #2
My guess you have a bad spring. If so, it can be rebuilt cheaply enough.
donniedu is offline   Reply With Quote
Old 05-17-2018, 08:47 PM   #3
Donít the slide toppers have an anti-billow device to keep them from unwinding when the slide is in?
2017 Rockwood 2703WS - Sold
2015 Keystone Sprinter 333FWFLS
2017 F250, 6.2 Gas, 3.73 Axle, 2902 lb Payload
If women don't find you handsome, at least they should find you handy!
andymil is offline   Reply With Quote
Old 05-17-2018, 08:49 PM   #4
Just as confused as you
Scrapper's Avatar
Many times when they are installed the spring is not wound tight enough. The was a fellow forum member that had to tighten his up some more by giving it 8 more turns on the spring. His was the Dometic toppers so other brands may be different. On Dometic toppers there is a spring on each end.
Richard & Jill
Camping since 1989, seasonal since 2000
Old 05-17-2018, 08:51 PM   #5
No anti billow on this one.. I did find one on Amazon.
Old 05-17-2018, 09:13 PM   #6
Scrapper's Avatar
There was another member last week who didn't have an anti-billow device on his. The installer didn't put it on. There is 2 parts to the anti-billow device, a short arm that goes on the tube and a stop piece that goes on the side of the RV.
Richard & Jill
slide
