Old 01-01-2020, 10:59 PM   #1
Slideout leak at window frame
Hi. I am new to the thread, and joined mainly to investigate possible solutions to my leaky living room window (frame, NOT glass) in the large slide-out on our 2016 berkshire XLT 43-A. I have checked the exterior glass-to-wall interface seal, and even applied some silicone sealant... still, after steady rains, i get a pretty frequent drip from where the metal frame is attached to the inside of the slideout wall up near the shade reels. I'm thinking the slideout wall attaching flange under the slideout topper has a breached seal. My leak does seem to occur once water has dripped/blown under the slideout topper. Familiar to anyone? Any suggestions will be greatly appreciated! Will further investigate when weather improves....
Jobeerbon Schlobby is offline   Reply With Quote
Old 01-02-2020, 08:26 AM   #2
cat1956's Avatar
If you have sealed the outside of the window then I think that's the next place I would check.
Tommy and Wanda
2014 Flagstaff 27RLWS
2017 Ram 1500 5.7 Hemi
Equal-i-zer 1,200/12,000 Weight Distribution w/ 4-Point Sway Control
cat1956 is offline   Reply With Quote
Old 01-02-2020, 08:39 AM   #3
Head Rambler
It sounds more like the slide roof is leaking than the window frame.
If you do find it, I suggest repairing it with Eternabond tape.
If you can't find it, it may be worthwhile to have a Sealtech leak detection ran on the RV.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 01-14-2020, 09:50 AM   #4
Commercial Member
ES_FR's Avatar
Jobeerbon Schlobby,
We would be happy to assist you with your 2016 Berkshire XLT. Because your ongoing satisfaction is very important to us, we invite you to contact Mike Winterrowd in our Customer service department through the following personalized and direct link: http://www.forestriverinc.com/Direct...45921979438975.
This direct link is provided for your convenience in order that we may resolve your concerns as quickly as possible. We will strive to respond to you within 24 hours of receiving your correspondence.
Respectfully,
Forest River
ES_FR is offline   Reply With Quote
frame, leak, slide, window
