Old 08-04-2016, 09:30 PM   #1
Soria awning hold down
I need to know if there is any way to tie down a Solara awning. Old coots said his brackets won't work and I would like to have a way of securing this thing so I can sit under it in a storm and not have to worry about it turning into a parachute.
railroaderone is offline   Reply With Quote
Old 08-04-2016, 09:37 PM   #2
Wobbles's Avatar
Can you post a picture of it and a second picture showing the awning rolled out displaying the very end?
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is offline   Reply With Quote
Old 08-04-2016, 09:41 PM   #3
Wobbles's Avatar
Does it look like this?
Bob & Michelle
Old 08-04-2016, 10:21 PM   #4
Wobbles's Avatar
Took mine apart so you can see how to mount it. The OC backets work perfect. Do not use the cheapo ratchet straps, spend a few more dollars.
ID:	116341   Click image for larger version
ID:	116342   Click image for larger version
Bob & Michelle
Old 08-05-2016, 04:53 AM   #5
I've been using the OC brackets on my Solera awning for two years. Mounted just like above. Work great.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2019: 34 nights camped
Teamfour is offline   Reply With Quote
Old 08-05-2016, 01:18 PM   #6
I needed support for my patio room on my new trailer which has a Solaria electric awning and could not find any available on line.
So I made my own supports out of the an old pair of manual awning rafters ( from a storm damaged awning), a pair of large foam padded d-rings and ratchet straps.
I squared the ends of the rafters and installed plastic plugs for the poles with a small ss screw in the top plug.
The poles are inserted in to the accessory grove of the awning and the d-rings are clipped on the shafts at each end with the ratchet straps to ground anchors.
They work great and are easy to put up, take down, are adjustable and light weight.
panamabear is offline   Reply With Quote
Old 08-05-2016, 04:12 PM   #7
Tom48's Avatar
Originally Posted by panamabear View Post
i needed support for my patio room on my new trailer which has a solaria electric awning and could not find any available on line.
So i made my own supports out of the an old pair of manual awning rafters ( from a storm damaged awning), a pair of large foam padded d-rings and ratchet straps.
post pictures please.
Tom48 is offline   Reply With Quote
Old 08-05-2016, 04:14 PM   #8
X2
Lee and Anne
Old 08-06-2016, 01:51 PM   #9
Here are some photos
Old 08-06-2016, 01:55 PM   #10
Another photo showing the D-rings, straps, and anchors
Old 08-06-2016, 05:02 PM   #11
Question wobbles did your have a screw above where the bracket is now?
Thanks for the pics
Old 08-06-2016, 05:21 PM   #12
Screw is in the center of the top plug to keep the pole from falling
Old 08-06-2016, 05:29 PM   #13
Wobbles's Avatar
Thanks for the pics
In my third post and third picture you can see the chrome/silver screw that is how the manufacturer mounts the head to the metal supports. In my second post I show the head without any metal mounted. You can see on the stem of that, where the chrome/silver screw screws into.
The OC brackets come with two pre-drilled holes. I chose not to interfere with the factory mount and drilled two below where the stem sits mounted. Extend your awning and get on a step ladder and you will see how to avoid the existing setup.
Had an experience this spring where things out of the blue got wicked bad and was cautiously enjoying how it was working when a poor soul across the lane was loosing his awning. Myself and another camper, my buddy, ran over to literally hold onto his, to keep it from going over the top of his TT.
I felt pretty darn good about how it worked. I have not had a solid promise since I buried my parents some twenty years ago, but the system makes makes me feel good.
Bob & Michelle
Old 08-06-2016, 07:16 PM   #14
Don't recall saying my brackets wouldn't work on the Solara awning.
Old 08-06-2016, 07:22 PM   #15
Maybe I miss read your pm if I did I applogize for ant misunderstanding
Old 08-06-2016, 07:33 PM   #16
According to Wobbles, they work just fine. I would imagine you could also use the factory bolt/screw also if the strap tab clears the motor enough to allow hooking the ratchet strap.
Old 10-07-2016, 11:01 AM   #17
Finally got to go camping and set up my screen room on my Solara awning with my homemade support poles.
Wind is currently at about 25 miles an hour all is good.
at St Andrews state park in sunny Florida
ID:	122331   Click image for larger version
Old 01-03-2017, 09:04 AM   #18
gmann55's Avatar
I used a piece of 1/8" flat steel approximately 3" x3" and drilled a 3/8" hole in it! Then welled a 6" piece of 3/8" Rerod in it so that the poles won't push into the ground and can't be kicked out by the kids playing! Half the rerod pushes into the ground and the other half sticks up so the pole will slide over it and keep the pole from moving or sinking into the ground!
gmann55 is offline   Reply With Quote
Old 01-03-2017, 09:32 AM   #19
JustB_Rad's Avatar
I've had success using long straps and 12" spikes with no poles. I take spikes and pound them into the ground 2 or 3 feet past the end of the awning, and pull the strap tight between the awning and the spike. You don't have to pull too hard, it's all about the angle of the pull, it's almost as if you're trying to pull the awning more laterally than down to keep the stretch in the material. If you just pull down, the awing will still become a sail, if you pull out, it stays stretched out for the most part.
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
Nights Camped - (2014) - 16 in 6 trips (2015) - 20 in 6 trips
(2016) - 21 in 7 trips
(2017) - 12 in 3 and going seasonal for at least the rest of the year!
JustB_Rad is offline   Reply With Quote
Old 01-03-2017, 05:11 PM   #20
The poles just take the load off the struts and flimsy support arms of the power awnings and keep the awning from flopping up and down.
awning
