Old 06-18-2015, 07:01 AM   #1
Left Coast
Stained glass
Want to change entry door window glass to stained glass type... anybody found any that are already made....or, who makes 'em?
Old 06-18-2015, 07:33 AM   #2
Real (Leaded Stained Glass) would be a (Bad Deal) in a RV door. Fake stained glass can be installed by any Glass Shop! Youroo!!
Old 06-18-2015, 10:07 AM   #3
Left Coast
Vibrations? Do my own install.
Old 07-05-2015, 12:09 AM   #4
Crockett's Avatar
seen it done once. i had to change the bezel on the entry door window. thought it was caulked in place. i was very young. laid door flat and watched it drop slow motion to the concrete and quietly shatter. got a student at the college to make another one. maybe plexiglass in front to seal? then shim inside bezel for different in glass thickness?..it did look awesome. american clipper motorhome with a stained glass american clipper ship in the door...
Crockett is offline   Reply With Quote
Old 07-05-2015, 12:52 AM   #5
TimVWulp's Avatar
Hi Sterling Enterprises Stained glass entry door windows will be at the Goshen Frog rally
Hope this helps Tim
TimVWulp is offline   Reply With Quote
Old 07-06-2015, 05:57 PM   #6
Left Coast
Hope this helps Tim
Kinda wish I was going....now!
Old 07-06-2015, 06:16 PM   #7
Cyber Phrenologist
Radio's Avatar
I originally planned to use automotive type window tint film, but found it expensive and boring, with various uninteresting shades of black, grey and brown it would indeed keep heat and light out. And make the trailer seem like a portable dungeon.
So I looked at Home Depot and found this:
Artscape 24 in. x 36 in. Magnolia Decorative Window Film-01-0113 - The Home Depot
Cost $21 and will cover more than one RV door window (at least 2, maybe 3) and comes in several interesting patterns.
Install is a typical wet the film and glass with soapy water type install.
However, the inside part of the door glass has a textured finish to it and the film will not work well if at all on the textured glass. The outside is smooth. Therefore the glass must be turned around.
You'll need some sealant to seal up the window again and a razor blade to scrape all the old seal off the glass and frame. I recommend against the use of an electric screwdriver as the plastic frame seemed easy to strip out. Also recommend a helper since the 2 frame halves AND THE GLASS will fall right out once the last screw is removed. Extra hands will help especially during reassembly. Apply the window film per manufactures instructions while you have the glass out of the frame for the best looking results.
No, it ain't real, but it ain't real expensive, either.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 07-06-2015, 06:26 PM   #8
Left Coast
Thanks...I've read your post from before. The reason I'm exploring this is the other day I was having the tv's air re-charged and a guy with a m/h was there for the same thing. He had a stained window and said he'd got his in Quartside,Ar......Looked good.
Old 07-06-2015, 06:31 PM   #9
Cyber Phrenologist
Radio's Avatar
And we have the same, or nearly the same, trailer.
Old 07-06-2015, 06:36 PM   #10
Left Coast
I know that.....
