Old 05-18-2019, 11:58 PM   #1
Storage Compartment Door Latch/Lock Grommet/Gasket
The rubber grommets that line and insulate my storage compartment latches (thumb latch and locks) have deteriorated and I am having a heck of a time finding replacements. They appear to be standard 7/8" locks/latches for a Forest River EVO TT. Any tips would be appreciated. Thanks!
wyz3rd is offline   Reply With Quote
Old 05-19-2019, 12:18 AM   #2
CincyGus's Avatar
Hmmmm. I've never seen a rubber grommet for latches on compartments.
Are you talking about the rubber seal around the edge of the compartment door? If not and you actually have rubber grommets around the latches, I'm not going to be much help. Might replace it with Butyl tape but many campers have nothing there, just contact between the latch/lock and the nut on the inside to tighten it.
A picture would help if that possible. You can use this link to upload and copy the link into a post.
http://photoposting.is-great.net/?i=3
2015 GMC 2500K Denali, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart
CincyGus is offline   Reply With Quote
Old 05-19-2019, 02:24 PM   #3
External Lock/Latch Grommets
Here is a picture of what I am talking about. They are the rubber grommets insulating the latches/locks on my external storage compartment doors. I need to replace them as you can see they are deteriorated.
ID:	204959   Click image for larger version
Old 05-23-2019, 11:04 AM   #4
I'm having the same problem, too. But my rig is another brand & painted. If the rubber gasket isn't replaced, it will scar the paint. I hope someone can help us.
B. Sibley
BarbSibley is offline   Reply With Quote
Old 05-23-2019, 11:24 AM   #5
I couldn't believe something like that would be too hard to find.
It is...it's like these things don't exist. Every picture of a lock shows a rubber gasket/washer but by themselves they seem to not exist.
I wonder if you took one of the cylinders to the hardware store they could find an o-ring or rubber washer that would work?
2018 Wolfpack 24PACK14+
2008 Toyota Tundra
2017 HD Limited
smkauffman is offline   Reply With Quote
Old 05-23-2019, 02:40 PM   #6
swampdonkey772's Avatar
A rubber washer will work thats what i did. I've also used a hose washer in the past
swampdonkey772 is offline   Reply With Quote
Old 05-23-2019, 02:45 PM   #7
Mine isn't that thick, but I do have a box of rubber gaskets at home. I'll just have to find the box & see if any matches. I would think that thick, the lock would be hard to turn. I had that happen when I tightened that lock 6 months ago.
B. Sibley
Old 05-26-2019, 05:08 PM   #8
larry2c's Avatar
I have no help for the OP but I have the same problem. Maybe they want us to buy a complete new latch instead of selling us a $.05 gasket/washer!
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Two shedding mutts
larry2c is offline   Reply With Quote
Old 05-26-2019, 05:19 PM   #9
HONDAMAN174's Avatar
Hereís what I have found and using. I change them almost every year now due to uv:
Just glad to get away
Old 05-26-2019, 08:49 PM   #10
Here ya go, rubber gasket.
2017.5 Forester 3051S
2016 Honda Accord
Steve-W is offline   Reply With Quote
door, gas, lock, storage
