Old 04-04-2012, 09:25 PM   #1
Anacortesians
Structural attachment of driver's side forward cargo bay door
I have an issue with the top rail that carries the hinges for the forward-most cargo bay door on my '02 Georgetown 325. The rail seems to have become detached from whetever it's supposed to be fastened to at the front corner.
Without a major dismantling (or cutting out pieces) of the bay's ceiling, I can't figure out what might have failed.
There's some evidence that the driver's side front corner may have been involved in some kind of damage incident (mis-alignment of the corne window is the most obvious.
The top edge of the door sticks out from the body about 3/8ths of an inch when the door is closed, and the top of the door moves around as it's opened. I'd appreciate any ideas about getting into the structure and figuring out what the problem is.
Frank and Eileen
No longer RVers or FR owners
Old 04-09-2012, 08:12 PM   #2
Roy
Can not offer any solution to the problem but thought you might want to know that I have the identical problem. I have a 2004 Georgetown Model 342 35 foot model I have owned since new. Never been in an accident but Forest River had replaced both sidewalls when it was new. I'm sure they must have removed the molding for storage door attachment when doing the repair.
If you get a solution would appreciate your sharing the info.
Roy is offline   Reply With Quote
