Old 07-13-2019, 12:57 PM   #1
tie down
I'm using the OC brackets and emt poles for my awning, but I'm having a hard time getting an anchor point in the ground.
How many pounds of concrete do you think I need in a five gallon bucket to hold my awning down.
I'm thinking 40 pounds but wanted some other oppions
2016 wildwood x-lite 241qbxl
being jurked down the road by the beast 2007 Dodge ram 2500
5.9 cummins g56 Trans southbend clutch and a smarty
railroaderone is offline   Reply With Quote
Old 07-13-2019, 01:03 PM   #2
Buckets become projectiles.
Use something like the 'Claw.'
They are made to tie down aircraft.
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 07-13-2019, 01:08 PM   #3
Deployed...Click image for larger version
ID:	209737Click image for larger version
Old 07-13-2019, 01:35 PM   #4
Will these work good at myrtle Beach with nothing but sand
Old 07-15-2019, 10:30 AM   #5
They work good but I'm certainly not going to tell you they will work at Myrtle Beach with nothing but sand. Only YOU can decide.
In reality what works in only sand... not much IMHO.
You may want to look into something like these...
Old 07-15-2019, 10:42 AM   #6
jeff64's Avatar
I use the old Camco corkscrew type, like you'd put a pet on, and happy with those but, sand is a different story. How bout a couple of empty 5 gal buckets and fill them with water? Full would be roughly 40 lbs. Or if you carry a couple jerry cans as I do, tie off to them maybe?
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
