Old 09-07-2015, 03:41 PM   #1
bigbird's Avatar
tighten up the slide out topper awning
i have a 2011 FR sierria 345ret ..............the awnings on the 2 big slides fill up and hold water! can i tighten up the awnings? can it be done??
i have search for an answer so if this is a common thing i am sorry! been the owner of this 5th wheel for 10months!! i love it
2011 forest river sierra 345ret
2012 chevy sliverado 2500HD
bigbird is offline   Reply With Quote
Old 09-16-2015, 10:21 PM   #2
Can you try fitting something like a soccer ball under them? Anything along that line will of course have to be removed before closing the slide, but, it would support the center.
I am facing this and have never had them before. Your complaint is common one though.
Charles & Martha Myatt
2009 Duramax w/Transfer Flow Fuel Tank
2016 Flagstaff V-Lite 30WFKSS
Almost South of the Border
whatsupchuck is offline   Reply With Quote
Old 09-17-2015, 11:13 AM   #3
bigbird's Avatar
I may try that. Some suggested a PVC frame.
Old 09-17-2015, 11:37 AM   #4
dieselguy's Avatar
You can tighten up the fabric, but you'll always have water pool on a slide topper ... it's just the way that plays out. Soccer balls, big bungee cords, PVC framing are other alternatives. If you do go at the fabric ... read up on the procedure as the spring is stout and there is a reccomended number of turns in relation to awning size found in that reading.
dieselguy is offline   Reply With Quote
awning, slide, slide out
