Tightened door lock too much t oh?
I replaced the door lock with one with a keypad, but in trying to tighten it up so it would seal ok on the outside I tightened it a little too much as you can feel the metal on the outside bow slightly in and a little also on the outside on the fiberglass.
I am wondering if it is worth it to take out the assy, try to fix the door then reinforcing the hole then reassemble. There is no support, the door is just a piece of Styrofoam, seems difficult to tighten w/o warpidge.
