Old 01-02-2013, 02:38 PM   #11
Traveling Two
jerryliving's Avatar
I have had two motors replaced (under warranty) that I suspect were caused by the switch initially sticking. If there is a fuse, I couldn't find it. I watch to make sure that the switch doesn't stick "again". The dealer said he checked it but found no problem. Something to watch out for though.
jerryliving is offline   Reply With Quote
Old 01-02-2013, 02:38 PM   #12
papap's Avatar
Reason
Just another reason why I wish I had the non powered awning.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 01-02-2013, 02:39 PM   #13
papap's Avatar
Fuse
My fuse is in a box right inside the door. Sure will be watching switch closer now.
Old 01-02-2013, 04:31 PM   #14
Traveling Two
Was your fuse in the switch box behind switch? I've looked in that box but didn't find anything. Guess it didn't really matter since the motor burned out and the fuse apparently didn't.
Old 01-03-2013, 10:09 AM   #15
papap's Avatar
No the fuse is in a metal panel that has 2 thumb screws on the left of switch. its one of those small mimi fuses.
Old 01-22-2013, 09:50 PM   #16
papap's Avatar
Motor
Replaced the motor today. Very easy one man job.
Old 01-26-2013, 10:15 AM   #17
SYE
SYE's Avatar
Okay, I have a weird question. Does anyone know nwhere the wires are located for the power awning in a Columbus 295, I know behind the switch but I am trying to figure out if where the wires go out to the awning is in =side if the walls or somewhere in a storage compartment because the awning is all the way foreward on the front.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 01-26-2013, 10:24 AM   #18
TURBS's Avatar
Normally the go through the walls and either up from the bottom or down from the ceiling into the control center.
Turbs
Old 01-26-2013, 10:27 AM   #19
SYE
SYE's Avatar
I am just looking for the easiest place to put this kit. I liked yours how it was in the storage compartment.
Scott & Vicki
Old 01-26-2013, 10:30 AM   #20
TURBS's Avatar
Yes mine works good there but alas I had wires available there.
Now doing this I can only use the remote option and not the rocker switch option.
awning
