Old 12-15-2012, 04:24 PM   #1
DAISY BOYKIN's Avatar
Trouble with awning poles
You better be careful about the "OLD COOT" add on stuff, this is what you will get when you buy his stuff. Bent my fine electronic auto dump awning
Cover arm and about cut my rear door "ASSIST" handle into.
His instructions are not too clear and are really confusing, even the pictures he supplies are not too clear.
When we get to "Moore Haven" for the kick back rally, the "OIC" (one in charge)will be taking care of him for sure. She carries a big stick and does not talk softly!!!!!!!
Name:	OLD COOT MISTAKE 001.jpg
ID:	22305   Click image for larger version
Name:	OLD COOT MISTAKE 002.jpg
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 12-15-2012, 07:01 PM   #2
Originally Posted by DAISY BOYKIN View Post
You better be careful about the "OLD COOT" add on stuff, this is what you will get when you buy his stuff. Bent my fine electronic auto dump awning Cover arm and about cut my rear door "ASSIST" handle into.
Don't know what happened, can you explain? Sent you a pm to give me a call.
Old 12-16-2012, 08:38 AM   #3
Herk7769's Avatar
These posts moved from another unrelated thread.
Herk
HAM CALLSIGN - KC3FFW
Old 12-16-2012, 08:48 AM   #4
Herk7769's Avatar
WOW Sid! So sorry man.
When you mounted the lower brackets, what kind of bolts did you use?
There is not a lot of room to clear the operating arms and pop rivets were recommended and all photos of installations showed pop rivets being used.
These photos are from other installs where members posted photos. It looks like your lower retaining bracket might have been mounted too high and/or in the way of the other moving parts.
I did retract mine the first time using Turbo's remote control to make sure it would not hit anything as it retracted. There were no problems because I made sure the bracket would be no where near the other moving parts.
ID:	22332   Click image for larger version
ID:	22333   Click image for larger version
ID:	22334   Click image for larger version
ID:	22335   Click image for larger version
Old 12-16-2012, 09:26 AM   #5
Lynkage's Avatar
Was this "auto dump" function enabled while the poles were erect and were tied down?
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
Old 12-16-2012, 09:40 AM   #6
Herk7769's Avatar
It appears from the photos the trouble occurred on retraction.
Old 12-16-2012, 10:10 AM   #7
Lynkage's Avatar
I have not seen many "Awning" incidents to know from a photo that is was going in or out, but it would seem to me that, this would be a great time to invest in Turbs remote awning setup to watch what is happening when it all rolls up or out.
This must have been the first time it was tried with the poles installed then?
Shane & Antoinette
Old 12-16-2012, 11:58 AM   #8
The poles should have nothing to do with retracting or deploying the awning. If the poles are stowed, they do not interfere with the functioning of the arms. If they are swinging loose, they just swing in with the arms. If the awning is tied down with the poles deployed, the motor will not be able to move the awning or utilize the wind/auto dump feature as the awning roller tube is in a fixed position by the poles and ratchet straps.
Old 12-16-2012, 01:13 PM   #9
Lynkage's Avatar
That is what I was trying to allude to.
Shane & Antoinette
Old 12-16-2012, 01:43 PM   #10
GASPEDDLER's Avatar
I wonder what type of fastener he used as well. I used pop rivets. The position of the bracket looks OK, my brackets are also mounted at that level. There ARE moving parts at that level and any fastener other than a rivet (which was recommended) would most likely make contact with them resulting in a failure.
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
awning
