Old 05-08-2013, 04:01 PM   #1
Turn signal, brake light problems
1998 Forest River Reflection. If u turn the turn signal either way it doesn't blink, just turns that turn light on in the front and back. Replaced turn signal flasher module and still the same result. If you hit the brakes the brake lights come on and both of the turn signals in the front. The brakes and the turn signal light is the same light in the rear. Also, if your turn on the headlights and dash lights the gas gauge goes down the brighter u turn up the dash lights. Wierd stuff. Any ideas?
Jimweee is offline   Reply With Quote
Old 05-08-2013, 04:16 PM   #2
I would start checking for a bad ground either at the tv or the trailer.
A bad ground will make trailer lights do very strange things.
Old 05-08-2013, 04:21 PM   #3
U don't have a trailer hooked up. Just the RV.
But u will check the ground at the dash. Thanks for the advice?
Old 05-08-2013, 04:42 PM   #4
question: with NO lights on....hit the brake, do the parking lights/dash lights come on? If so, one of your brake light bulbs is bad (2 filiments touching each other) or the 2 solder nubs on the bottom of the bulb have melted together.
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
