Old 09-07-2015, 01:35 AM   #1
unable to lock basement storage
we have a silverback 31RK and our key is unable to lock the basement door. we opened it and was re-arranging some items and when we went to lock the door it doesn't work. we can lock/unlock the other basement door on the opposite side of the 31RK.
there are about 6 varying size screws on the other side of the door which we cannot lock. Is this something where I can remove the screws and see if there is something stuck in the lock? or how would I get another door handle?
thanks in advance.
bill
stormy2000 is offline   Reply With Quote
Old 09-07-2015, 02:41 AM   #2
asquared's Avatar
Can you turn it to lock it when the door isn't closed? If you can then I would think something is in the way in the basement. If you can't then the problem is in the lock itself.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 09-07-2015, 02:54 AM   #3
No the key goes in but cannot turn. We can open/close the door, but cannot lock it.
Old 09-07-2015, 03:10 AM   #4
asquared's Avatar
Have tried spraying lock free or a silicone spray into the lock to see if the tumblers will loosen up and turn for you?
2014 Sabre 34REQS-6
Old 09-07-2015, 04:43 AM   #5
Witch Doctor's Avatar
If it is the slam type lock you would be better off adding a lock. Cheaper then the slam lock.
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-07-2015, 05:18 AM   #6
Will try spray o have wd40 would that work
Do most people add locks? We have slam type.
Old 09-07-2015, 05:40 AM   #7
RSchleder's Avatar
I've never added additional locks to any of the 12 RV's we've owned!
When you spray your lock with WD40. spray the key and insert it the lock, move it in and out several times. You should also insert the key slightly to "open" the keyway, then spray liberal amounts of WD into the keyway. If this fails to work you'll either need a new lock or a Locksmith. The issue with a new lock, of course, your same key probably won't work and you'll have an additional key to mess with. Good luck and please let us know how you make out.!!!!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 09-07-2015, 06:42 AM   #8
Tks will try that when i get back from shopping and post result
Old 09-07-2015, 11:35 AM   #9
Graphite only in locks. Wd 40 gums up.
NorSnrub is offline   Reply With Quote
Old 09-07-2015, 12:04 PM   #10
Agree with graphite only. several locksmiths have advised WD40 will help collect dirt and gunk while graphite doesn't. Graphite only makes lock parts turn easier not clog up with WD40
dannyshouse is offline   Reply With Quote
storage
