Old 03-13-2016, 11:32 AM   #1
Vertical supports for my awning
We are in a windy area and because of that I am running the electric awning in and out often when at most times I would like to leave it out. So I would like to support the awning in the extended position with poles then strap the awning down to our concrete pad. I see where folks have made their own supports out of 2 different size aluminum conduit but I have limited tools here. What commercially available support poles are there out there and what are your experiences?
Patrick45 is offline   Reply With Quote
Old 03-13-2016, 11:39 AM   #2
I sell the awning pole attaching kits. Kits include 2 upper pole attaching brackets, 2 ss pole pivot bolts & ss nyloc nuts, 2 hitch pins, 2 lower stow brackets, 4 pop rivets, (2) 1/4 x 3/4 ss bolts & ss nyloc nuts for optional bolts for the upper brackets, instructions and pole dwg sketch. Price is $85 includes USPS Priority Mail. PayPal only. Just need your PP login name and current shipping address.
Wooster 6 ft.-12 ft. Sherlock Extension Pole-00R0560000 - The Home Depot
Old 03-13-2016, 11:40 AM   #3
Really, Do a Search at the Top or go to Classifieds,under Poles and Brackets! Youroo!!
Old 03-13-2016, 11:54 AM   #4
TURBS's Avatar
Turbs awning pole install with pics. http://www.forestriverforums.com/for...d.php?t=102583
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 03-13-2016, 11:55 AM   #5
TURBS's Avatar
Awning hold down poles. http://www.forestriverforums.com/for...ad.php?t=85132
Everything you need.
2015 Columbus 320RS
2008 2500HD Duramax
Old 03-13-2016, 12:55 PM   #6
Awning poles
I got a setup from Old Coot which is great and well worth the cost. But instead of using the lower brackets and leaving the poles on all the time I made some sockets that accept the large screw in ends of the painters poles from Home Depot. I then got a couple of good paint rollers from HD (the green ones) and cut the handles off. The handles are hollow so I filled them with epoxy. I then drilled holes in them and attached them to the upped brackets just like you would the poles you see people do. When I arrive at the camp site I get out the poles and screw them in. I also attach the hold down straps. I attached a small hook to each strap end and put it on the Old Coot awning bracket with one of those long reach grabber things. Works great and has held in 30+ MPH winds just fine. Side benefit is that I still have the unaltered poles to paint the high walls in the house and put up the Christmas lights.
2015 Roo 23IKSS
2016 F150 SuperCrew 3.5 EcoBoost
Kanga99 is offline   Reply With Quote
Old 03-13-2016, 01:14 PM   #7
Thank you so much
Old 03-13-2016, 02:18 PM   #8
I need info to order a pair of your famous awning pole brackets.I have pay pal and am ready to order. How long will they take to ship?
Harold Fay is offline   Reply With Quote
Old 03-13-2016, 02:40 PM   #9
Any pics of the product in use?
offduty11 is offline   Reply With Quote
Old 03-13-2016, 03:13 PM   #10
PM sent and can ship tomorrow.
Old 03-13-2016, 03:39 PM   #11
TURBS's Avatar
2015 Columbus 320RS
2008 2500HD Duramax
Old 03-13-2016, 03:54 PM   #12
A set of polished aluminum poles with brushed alum outer poles.
Name:	Front Pole Polished.JPG
ID:	101828   Click image for larger version
Name:	Front Stow Bracket Polished.JPG
ID:	101829   Click image for larger version
Name:	Rear Pole Polished.JPG
ID:	101832   Click image for larger version
Name:	Rear Stow Bracket Polished.JPG
Old 03-13-2016, 04:17 PM   #13
MCTroy
Turbs, our windjammer awnings pitch too high. I have tried holding the arm down and adjusting then via the screw clamp in the awning. That holds about 10 minutes and then they pop up. Would your poles hold the awning pitch down?
2015 Windjammer 3029 Diamond Edition
2018 Ram 2500
Ohio River Rat
MCTroy is offline   Reply With Quote
Old 03-13-2016, 04:23 PM   #14
NICE!!!!
Old 03-13-2016, 04:29 PM   #15
TURBS's Avatar
Yes they are fully adjustable!
2015 Columbus 320RS
2008 2500HD Duramax
Old 03-13-2016, 04:42 PM   #16
TURBS's Avatar
Poles are adjustable from 6' 4" to 8' 10" in 3" increments.
2015 Columbus 320RS
2008 2500HD Duramax
Old 03-13-2016, 10:02 PM   #17
mikejm
Oldcoot, mikejm here. Am interested in awning poles. Can you send pics and could they be attached to wooden deck?
Thanks,
mikejm
mikejm is offline   Reply With Quote
Old 03-14-2016, 06:39 AM   #18
Thanks,
mikejm
My poles have a 2-3/8" alum pad on the bottom that could be drilled for screws to attach to a wooden deck. PM me.
Old 03-14-2016, 08:49 AM   #19
Wolverine 1945's Avatar
Good looking pole sets Guys !!!
Wolverine 1945 is offline   Reply With Quote
Old 03-14-2016, 08:55 AM   #20
TURBS's Avatar
Thank you!
2015 Columbus 320RS
2008 2500HD Duramax
awning
