Old 03-29-2013, 04:36 PM   #1
Denver, CO
garbonz's Avatar
Window
I really, really want a window in the WC room (that's watercloset for you nautical folks). I found a 24X24 flush mount window and was wondering is there is any reason I shouldn't do this. I'm not sure where the aluminum frames are but figured that I can find out.
It should be a no brainier to do this?
2017 Fuse 23T
Old 03-29-2013, 04:50 PM   #2
As long as there aren't any aluminum frame members in the way, I don't see any issues. But if you find a frame member in the way, I would think twice. I don't imagine there would be any wiring in the way? Might be worth checking with FR, as once you start, there's no going back!
bakken is offline   Reply With Quote
Old 04-02-2013, 04:46 PM   #3
Denver, CO
garbonz's Avatar
Thx. I'll check it out
2017 Fuse 23T
Old 04-07-2013, 03:55 PM   #4
Displaced2's Avatar
Do you want the window to open?
If not, check about using same system as in entry door.
Displaced2 is offline   Reply With Quote
Old 04-11-2013, 07:42 PM   #5
Denver, CO
garbonz's Avatar
I want it to open to reduce fugitive odors.
2017 Fuse 23T
