Old 01-19-2019, 05:45 PM   #1
Window Latch Adjustment
One of our vertical sliding emergency exit windows will not latch when window is closed.
Hopefully, you can see in the pictures that the red piece that is supposed to go into a slot in the track is above the slot. Does anyone have similar, is the track adjustable?
ID:	194966   Click image for larger version
ID:	194967   Click image for larger version
2019 Salem Grand Villa 42DL
Seasonal camping on Lake Guntersville
Stymie is offline   Reply With Quote
Old 01-19-2019, 10:16 PM   #2
Smile
Any advice on how to rotate photos would be appreciated also.
Sorry to all having to stand on their head to view this...
Old 01-20-2019, 02:34 PM   #3
Keystoner's Avatar
You should be able to rotate the picture by opening it in your phone, go into edit, rotate and save. As for the window, did you try having someone on the outside pushing the frame inward.
Keystoner is offline   Reply With Quote
Old 01-20-2019, 07:39 PM   #4
On my computer, they open oriented correctly.
The problem is that the hole is further down than the window will travel.
Old 01-23-2019, 09:41 PM   #5
Adjusted the piece with holes that it latches into, all is well. Had to take the window that slides out to get to one of the set screws.
Sorry, didn't take photos. Next time i am out, I will try to remember in case someone else has same problem.
window
