Old 05-19-2010, 01:36 PM   #1
window leak
Has anyone ever had problems with the front window leaking? I had just gotten to our permanent site and noticed that there was a puddle of water on the countertop. This particular window is the one that doesnt open. I could see that the water had leaked from the bottom of the window onto the top of the sink counter. Would the likely culprit be a possible gap in the caulk around this window? I am hoping that is isnt a leak in the roof,, Any other places that I should also check? thanks
blue eyes is offline   Reply With Quote
Old 05-19-2010, 05:04 PM   #2
yvesm's Avatar
I had a window leak in my other camper (2001 Shamrock). I took the window out, cleaned out the old butyl tape, installed new butyl tape and remounted the window. After the tape stopped oosing out I applied a good grade of silicone caulking around the edge (outside)
2013 Prime Time 230 FBS
Days camped in 2013: April to November
Days camped in 2014...about 40
Days camped in 2015...more than 2014!!
yvesm is offline   Reply With Quote
Old 05-19-2010, 11:08 PM   #3
Few years ago, thought we had a leak at the window-that was where the water pulled. Actually turned out to be a section of exterior molding between roof and backwall that was not caulked during rv construction.
granite is offline   Reply With Quote
Old 05-20-2010, 03:56 AM   #4
I found the butyl tape was folded under at one corner of the front window causing the leak. Sealing from the outside was only a temporary fix.
Remove the window and reseal with new butyl tape and seal the outside edge with Procell RV sealant. No leak after that!
Here is a link with some pictures of what I found.
John U
2007 Rockwood 8315SS
2014 Silverado 2500HD 6.0L
midnightpumpkin is offline   Reply With Quote
