Old 07-20-2015, 11:07 PM   #1
Window problem
I have a new 2015 Silverback 33IL and the rear escape window fell off. The unit was parked in the yard with the window open. Out side temp was about 95. It did not break so I was able to put it back on with the help of duck tape until I can get it fixed. It came unglued at the top hinge. Any one have this problem?
JohnG is offline   Reply With Quote
Old 07-22-2015, 12:03 PM   #2
While I have not had that problem, I have come to understand that the escape window is basically designed as a one time use window. It isn't designed to be opened and closed on a regular basis. I've read a number of stories about the hinge breaking and the window falling out. Go figure -------
bruceatlam is offline   Reply With Quote
Old 07-22-2015, 12:09 PM   #3
Georgia Rally Coordinator
aceinspp's Avatar
These newer frame less windows have issues with the glue not holding. My new camper had the bottom closer come loose from window and they where going to replace but then they decided to re glue. So far it's holding. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped 2017 62
Days camped 2018 67
Days camped 2019 57
aceinspp is online now   Reply With Quote
Old 07-22-2015, 02:44 PM   #4
Window problem
Thanks for the info. I have not heard that it is a onetime only window. I will check it out and get back to you. I have heard back from my dealer and he said Ceder Creek will replace it. Also window manufacture is involved and may send a repair man out to fix it.
Old 07-23-2015, 09:22 PM   #5
Mine has a screen....wouldn't think they'd put a screen on a one time use window????
Dan-tastic is offline   Reply With Quote
Old 07-24-2015, 10:21 PM   #6
Window problem
Mine dose also. Window manufacture is shipping a new one. The dealer I purchased my RV from has been very helpful. Tropical RV in Fort Pierce FL.
Old 08-03-2015, 08:56 PM   #7
The window in our 29Re --bedroom----disappeared the day we arrived home from Florida end of April.....We used window on a daily basis both day and night.....I had to order a new window thru dealer and I installed it....Fehr was the manufacturer...Called them and they said that there was no reason not to use this "escape" window for air circulation.....All the other windows seem to be the same construction--hinged on top.....Hope to hear from others that have had this problem so I can go back to dealer/FR.... Cost was approx $400.00 Cdn......J
Jim in Halifax is offline   Reply With Quote
