Old 09-27-2018, 02:02 PM   #1
Navaner's Avatar
Window reseal
Hey everyone.
My big bay window is no longer glued to the frame.
How do you remove the metal tabs holding the window in place?Click image for larger version
ID:	187662Click image for larger version
Big Dawg
2015 Titan pro 4 x
2016 forest river vibe 268rks
Navaner is offline   Reply With Quote
Old 10-05-2018, 04:03 PM   #2
Navaner's Avatar
Originally Posted by Navaner View Post
Hey everyone.
How do you remove the metal tabs holding the window in place?Attachment 187662Attachment 187663
I was able to remove them with finesse using 2 flat screw drivers. Starting with the bottom clip for easy visibility was my approach.
Not pressing against the glass was key.
I got it out of the chanel and did the same procedure with the top clip. Once i got the two clips removed I asked for 2 helpers.
One inside the trailer with a plastic scalper (credit card or bank card would work).
The person inside ran the plastic scalper across the frame of the window to break away the remaining glue that was still adhering. My other helper and I held thw window outside until we could set it down.
Once we removed it I got to cleaning the old glue and prep it for urethane.
The stuff they use on car windows.
I put a good coat of urethane and installed the window.
I let it cure for 24 hours.
Been trouble free so far.
ID:	188370Click image for larger version
Big Dawg
2015 Titan pro 4 x
seal, window
