Old 05-22-2014, 01:47 PM   #11
I have a 2000 Georgetown 303, no slides, the rubber seals around the exterior windows have shrunk and water is getting in. The RV dealer searched and had no luck for replacement other than new windows. I just had a new roof installed with the dealer. They suggested contacting a glass repair service. Any suggestions on replacement seals or should I just silicone or butyl rubber tape?
shootermik is offline   Reply With Quote
Old 05-22-2014, 02:44 PM   #12
bend302's Avatar
Do not use silicone. I was told by a window technician that real window sealant would never stick where silicone was used and silicone often fails to seal well when applied over the rubber window sealant.
Just my $0.02
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 05-23-2014, 06:40 AM   #13
von
after pulling all my windows and seeing that the tape although leaking in places was still pliable (almost like silly putty) at 8 years old! go with the tape, i used silicone to finish off the look and it cant hurt!
von is offline   Reply With Quote
Old 05-23-2014, 11:26 PM   #14
I am new to RVing and have a new 5er sitting in the driveway. I have all the windows shut as we were having rain a while back. This has made the inside of the rig quite warm. This may sound silly but since the windows are so flush with the outside walls, if I leave the windows open and it rains, will the water come inside?
Thannks
dpersaud is offline   Reply With Quote
Old 05-23-2014, 11:38 PM   #15
Originally Posted by Todouble View Post
Why does everyone say not to use silicone on the outside of your rig? I see silicone on my new rig outside various places. Obviously the factory thinks it's ok. Just would like to know for future reference?
Based on my experience and reading, virtually nothing sticks to silicone, not even silicone. It's very difficult to remove when it eventually, inevitably goes bad. If you have to reseal anything it becomes more difficult to get an effective seal.
00buck is offline   Reply With Quote
Old 05-24-2014, 12:43 AM   #16
Oklahoma Proud
MillerTime's Avatar
X2
My experience exactly. I hate having to remove silicone from cars. About the only way to remove it is to grind away whatever its stuck too.
Butyl tape and window urethane (with the correct primer used to the application) is the only way to go.
Old 05-24-2014, 08:20 AM   #17
Denver, CO
garbonz's Avatar
Thannks
Answer to da hijack. The best way for ventilation is to have a ceiling vent hood on one or more vents and then crack open a window or two. I hate my flush windows cause they don't open much, but if you open then an inch or so they are very unlikely to let water in unless you have a REALLY strong wind.
2017 Fuse 23T
roo, roof
