Old 06-12-2016, 01:40 PM   #11
VinceU's Avatar
Originally Posted by chesba88 View Post
I believe there are actually only two Motors and they are both on the top one on each side there is a shift that goes from the top motor down to the bottom of the slide to turn the gears on the bottom. You were lucky this time but I would check where the wires connect to the motors on the top mine had the same problem because it just came unplugged. That could happen again to you. Go to YouTube and Google schwintek slide Motors you'll get a good education.
X2 top motors only, extension shafts and gears to the bottom tracks.
Old 06-13-2016, 07:34 AM   #12
Wolverine 1945's Avatar
It sure is GREAT when folks reply with there fixes !!!
Wolverine 1945 is online now   Reply With Quote
Old 06-13-2016, 08:07 AM   #13
Don't forget when running the Schwintek slides out and then back in to keep your finger on the button for an extra 4/5 seconds after they stop. This is to keep the motors in sync. Otherwise the slide will not stay straight and you have problems later.
Bob & Sharon, '18 Berkshire 34QS, 2018 Jeep Cherokee.
btritschler1437 is offline   Reply With Quote
slide, slide out
