Old 08-13-2017, 01:04 AM   #1
2 slide outs not working
I just bought a new 2017 Rockwood Windjammer 3025w. At home I have a heavy duty extension cord with a 30 amp plug. It plugs into a standard 120v house plug. I have a 30 amp to 50 amp adapter.
I have the new RV plugged into this and am getting power into the RV. I know it won't power much...but I have one AC running with lights on.
Now to the problem. I can get the bedroom slide to work. But the other 2 bigger slide outs will not go out. When I push the button on the control panel, I hear a beep...but nothing. So, is my power cord set up not giving it enough power to operate the 2 bigger slide outs? Or could this be something else?
djurden is offline   Reply With Quote
Old 08-13-2017, 05:12 AM   #2
NH Maple Maker
russhd1997's Avatar
The slide out motors are 12 volt and should work with no shore power. If your battery is good you have a problem elsewhere. Try connecting a battery charger to the battery and see if they work then.
Russ
2014 V Cross VIBE 822VRBS
2017 Silverado 1500 crew cab 4x4
russhd1997 is offline   Reply With Quote
Old 08-13-2017, 06:56 AM   #3
I don't have a battery charger. But I did plug the trailer's 7 pin plug into my truck with the engine running. Still not working.
Old 08-13-2017, 07:38 AM   #4
The truck wire is such a small guage that it can't carry much power, but I doubt that is your issue. Will they not work with either the remote or the manual switch? I suspect you have a blown fuse. There are fuses on the remote control panel (not the converter.) Have you checked those?
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is offline   Reply With Quote
Old 08-13-2017, 07:49 AM   #5
I figured it out!
I was trying to use buttons on the control panel to operate the 2 back slides. I found 2 buttons on the side of the island that operates those.
Old 08-13-2017, 10:15 AM   #6
Good. Thanks for letting us know. It helps others.
Andersen hitch
Old 08-13-2017, 06:11 PM   #7
Originally Posted by djurden View Post
I figured it out!
Are there 3 knobs on the control panel to operate the slides??????
Are they "turnable to CW and/or CCW direction"?
Were two of these closed? ie all the way cw?
Jim in Halifax is offline   Reply With Quote
Old 08-14-2017, 08:14 AM   #8
Wolverine 1945's Avatar
I figured it out!
Glad you figured it out !!!
I thought everyone owned a Battery Charger !!!
Guess they did not show you how to operate the slides on your walk thru ???
Wolverine 1945 is offline   Reply With Quote
slide, slide out
