Old 04-14-2014, 01:51 PM   #1
21fbrs slide seal question
There is a black "flapper" gasket on the bottom side of the slide that is divided by what looks like a steel u channel that houses the gears for the slide. This gasket is about an inch on either side form this u channel, allowing daylight in (if u look under the couch). I called the dealer and they stated the rubber seal will get bound and rip the whole thing off if it touches. Opinions? I thought if that true I could close the hole up myself when slide is out.
sdalton is offline   Reply With Quote
Old 05-12-2014, 04:49 PM   #2
want a Cat 293REX
interesting question, love to read the responses
boatless is offline   Reply With Quote
Old 05-12-2014, 07:58 PM   #3
JohnF's Avatar
My seal is cut right at the channel. It isn’t a tight seal but should keep out most air.
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
JohnF is offline   Reply With Quote
Old 05-13-2014, 07:02 PM   #4
want a Cat 293REX
and oh, um, buggies?
slide
