Old 07-27-2014, 02:38 AM   #1
28BH slide trouble
I have a 2010 Grey Wolf 28BH and the slide will not come in. I press the rocker switch and nothing happens. Doe this model have a inline fuse that can be changed? I'm hooked to shore power and everything else electrical works. Could a bad battery be the problem? Thank you in advance.
sfontenot1969 is offline   Reply With Quote
Old 07-27-2014, 05:21 AM   #2
Witch Doctor's Avatar
Why are you re-posting this, You had the same post yesterday, did you try everything that was suggested.? Did you check the 15 amp plug in fuse in the panel? Should be labeled S/O, only other fuse which is 40 amp by your battery which is restable. Other then that you need to check the power at the switch in and out. It's easier to get help with one post then two of the same so people can see what you have tried.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
28bh, slide
