Old 07-14-2014, 06:48 PM   #1
370XL main slide won't go back in
Hi I am new here and just purchased a 2007 Georgetown 370 XL private sale. I put the main slide out which is lippert system and now it does not go back in . When I hit the switch all it does is click at the solenoid. I have tried this plugged in 110 v and also with generator running. I see above the aux batteries on frame rail it looks like a new 100 amp breaker but it was not tripped. I called old owner but no one home. Any suggestions?? Thanks
stingjra is offline   Reply With Quote
Old 08-08-2014, 07:31 AM   #2
Check all the connection on the motor and the solenoid that operate the pump. Sounds like a loose connection. Just did the same thing on my 2008 370 GT.
gmann32 is offline   Reply With Quote
Old 08-08-2014, 08:31 AM   #3
I just install new solenoid and all is good now.
slide
