Old 11-10-2012, 02:01 PM   #11
Hello I was wondering do you mean the main fuse box or the one on the wall with all the switches as we are having the same problem with our Rockwood 8082ws.
Thanx Tracy
tracybet is offline   Reply With Quote
Old 11-10-2012, 03:28 PM   #12
Herk7769's Avatar
Thanx Tracy
What you call the "main fuse box;" I call the "power center" as as it contains the AC circuit breakers, the DC fuses and the Converter that converts 120 volt shore power into staged DC power to run your camper and charge your battery.
Attached to the same screw terminals as the battery wires, there are pigtail wires that go to fuses that do not fit into the typical power center. The fuses are located right behind the power center that must be unscrewed and slid forward to access the fuses located back there.
HAM CALLSIGN - KC3FFW
Old 11-10-2012, 04:38 PM   #13
Hello Thanx for your help, hubby is going to look at it in the morning will let you know how we get on.
Thanx Tracy
280, 8280ws
