Old 09-06-2012, 12:45 PM   #1
8280ws Wardrobe slide not working
Hello. I have an 8280ws Wardrobe slide not working. I was plugged in at campsite and everthing else works, even the couch/dinette slide but totally silent when tried the wardrobe. Had to bring in manually. Does anyone know where the fuse for this may be. I do not see one on the main fuse box and there was a fuse in front storage when you follow the lead off the positive of battery, changed that (30) but still nothing on slide.
Mike - Ottawa
'10 Rockwood 8280ws
2014 Ram 2500 SLT HD Crew Cab 4X4 3.73
Mike101 is offline   Reply With Quote
Old 09-07-2012, 06:46 AM   #2
Herk7769's Avatar
It is possible that the fuse is on a pigtail fuse holder located behind the power center. Turn off the 120VAC AC (shore) power and Remove the 4 screws holding the power center to the wall and slide it out. Look to see if any of the pigtail fuses (there may be more than one) are blown.
HAM CALLSIGN - KC3FFW
Old 09-10-2012, 11:29 AM   #3
I assume you mean the whole fuse box ? Take that cover off and see what I can find ?
Mike - Ottawa
'10 Rockwood 8280ws
Old 09-10-2012, 11:38 AM   #4
TURBS's Avatar
Yes that's what he's suggesting.
Old 09-10-2012, 02:35 PM   #5
Herk7769's Avatar
Actually I was suggesting you slide the entire power center out of the wall and have you check behind it for fuse holders.
Old 09-13-2012, 10:13 AM   #6
Thanks for the plan of action. will do it while camping at Presquile provincial park this weekend
Mike - Ottawa
'10 Rockwood 8280ws
Old 10-19-2012, 03:56 PM   #7
herk you were 100% right "It is possible that the fuse is on a pigtail fuse holder located behind the power center." ..I was unable to get to the job so let the dealer do it for $50. The guy took 3 hours and tore apart the trailer, plus took off the underbelly to look for the fuse. He finally found it behind the power center. Said he has never seen this before and seems to be exclusive to the 2010 8280ws model !!
Wel at least I know if it ever happens again. herk 7769 rules
Mike
Mike - Ottawa
'10 Rockwood 8280ws
Old 10-19-2012, 04:09 PM   #8
Dave_Monica's Avatar
Good to hear that they found the problem and only nicked you for $50. I'll give you my thanks now should I ever have the same problem and need to find the fuse.
Dave
Old 10-25-2012, 12:29 PM   #9
Question; there is a fuse that comes off the battery, what is that for ?
Mike - Ottawa
'10 Rockwood 8280ws
Old 10-25-2012, 01:28 PM   #10
Herk7769's Avatar
Typically there are several possible "pigtail" type fuses and a resetting fuse (see photo) that come off the battery.
The square one with the button on the side is for the main battery protection and is usually 40 amps or less.
The pigtails are specific to the camper. They can be for:
1) Front landing gear (5th wheels)
2) Power Jack (TTs)
3) Main slide or slides (1 for each)
My 8526RLWS has 3 there plus the 40 amp main.
1) Landing gear - 30 amp
2) Left opposing slide - 30 amp
3) Right opposiong slide - 30 amp
The wardrobe slide fuse is located in a pigtail behind the power center.
Old 11-10-2012, 03:01 PM   #11
Hello I was wondering do you mean the main fuse box or the one on the wall with all the switches as we are having the same problem with our Rockwood 8082ws.
Thanx Tracy
tracybet is offline   Reply With Quote
Old 11-10-2012, 04:28 PM   #12
Herk7769's Avatar
Thanx Tracy
What you call the "main fuse box;" I call the "power center" as as it contains the AC circuit breakers, the DC fuses and the Converter that converts 120 volt shore power into staged DC power to run your camper and charge your battery.
Attached to the same screw terminals as the battery wires, there are pigtail wires that go to fuses that do not fit into the typical power center. The fuses are located right behind the power center that must be unscrewed and slid forward to access the fuses located back there.
Old 11-10-2012, 05:38 PM   #13
Hello Thanx for your help, hubby is going to look at it in the morning will let you know how we get on.
Thanx Tracy
280, 8280ws
