Old 12-28-2014, 02:22 AM   #1
99 Sierra 33FKSS Dead Slideout
I have a TT with a single slide out that doesn't seem to operate. I found the circuit breaker in the front underneath just behind battery. The pump now has power but doesn't click or hum. There are also 2 open ports on the top of the pump. The lines are connected to the 2 outside ports, with the 2 inside being open...anyone know if those are supposed to be plugged?
I can't find any owners manuals wiring schematics or documentation anywhere.
Motofixxer is offline   Reply With Quote
Old 12-28-2014, 08:05 PM   #2
The hydraulic pump is DMI Dewald. As I stated the power is now getting to the pump after changing the circuit breaker underneath. The fuses appear fine. There seems to be one labeled slide...but it looks good. The pump doesn't do anything from the switch on the wall or the pump itself. So I'm not sure now how to diagnose the problem. Maybe bad solenoids or something.
Old 12-28-2014, 08:52 PM   #3
Ok I think I found some diagrams...here http://support.powergearus.com/techd...ideout_Sys.pdf On page 16 are some diagrams that look right. So it appears Red is the batt 12v so at the switch there should be 12v? Then it looks like the blue lines and the green are the switched lines to activate the pump. So can I jumper a 12v to those and that should tell me if it works or not???
slide, sierra, slide out
