Old 06-19-2012, 09:15 PM   #1
mike06081969's Avatar
Adhesive all over slideout, any tips on removal?
I ran my slides out today to do some work under the trailer. When I did, the living room slide pulled the inner part of the rubber seal out with it on one side. I basically have two questions. 1) What is the best way to ensure that I have the seal firmly re-seated so I don't have to go through this again and 2) anybody have any suggestions on how to get that devil adhesive off the outside of the slide, windows, and rubber window seals? This stuff literally smeared all over the side of the slideout. I tried alcohol and bug/tar remover with a razor blade (very carefully) with minimal results. This unit has a gel coat finish, so I need something that won't damage it. Any help is appreciated! Thanks!
Mike in Tennessee
Former 2 time FR owner
2007 Crossroads Cruiser 30QB Fifth Wheel
2008 F-250 Lariat 4x4 6.4 Powerstroke
Firestone Ride-Rites w/cab control
mike06081969 is offline   Reply With Quote
Old 06-20-2012, 04:33 AM   #2
cardinal4fun's Avatar
Try GooGone, I had the same problem was able to get most of the stuff off.
3500 Ram 5.9l diesel
08 35 RLT Cardinal
5th Airborne Pin Box
cardinal4fun is offline   Reply With Quote
Old 06-20-2012, 11:21 AM   #3
Thanks. Looks like they have it at my local Wal Mart, so I'll pick a bottle up after work this evening and give it a try. I really appreciate it.
Did you have to do anything else to your seal or just re-seat it?
Mike in Tennessee
Old 06-20-2012, 03:43 PM   #4
Brigitte
boubou's Avatar
Curious to see an answer, same thing happened to mine
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
boubou is offline   Reply With Quote
Old 06-25-2012, 07:10 PM   #5
WisconsinCamper's Avatar
GooGone
After you get the seals back together you might want to get some "Slide Out Lube & Rubber Seal Conditioner" to prevent it from sticking to the slide out.
Gary
2001 E-350 7.3 Diesel - 2011 Coachmen 291QBSS
WisconsinCamper is offline   Reply With Quote
Old 06-25-2012, 07:14 PM   #6
racer30's Avatar
x2 on the updates.... my revere looks like Boubous first picture as well. What do people use to fix? just a basic black silicone?
2011 32ckds Shasta Revere
2009 Dodge Ram 1500slt
Moncton New Brunswick Canada
2012 NIGHTS CAMPED 43
racer30 is offline   Reply With Quote
Old 06-25-2012, 07:16 PM   #7
onetonford's Avatar
I have used Goof off which I bought from Homedepot(it took off the rubber marks from a tire blowout I had recently) also once you get your seal back in place use a silicone spray lube on seals it keeps it from dragging and pulling out.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 06-25-2012, 07:41 PM   #8
WD40 sure works on most adhesives and doesn't damage anything. Just make sure you use alcohol on the surface afterwards to remove any WD40 residue.
