Old 11-08-2012, 07:08 AM   #1
Adjust Bedroom Slide
Noticed on our 2010 28RKBS that the bedroom slide appears to not come out straight. When fully extended, the front inside seal is nearly an inch away from making contact with the wall. Measured the outside and true enough, the back edge is out nearly an inch further than the front.
Is a there a way adjust the? I read here about how to adjust it horizontally, but this is slightly different.
JJnLilly is offline   Reply With Quote
Old 11-16-2012, 09:47 AM   #2
Hi, I found you can go to Lippert Components for a manual to help you with the adjustment. Just do a googel search for them.
Skippkon is offline   Reply With Quote
Old 01-21-2013, 09:05 AM   #3
jr1
My 2011 wildcat leaks at the bottom of bedroom slide also can see daylight on right side of bed next to bed any ideals of promble
jr1 is offline   Reply With Quote
Old 01-21-2013, 09:24 AM   #4
H2oski
Look in the forest river forums "files section" at the top of the page in the geen bar. There is alot of manuals usershave up loaded. The lippert site is also a great source. The slides are pretty easy to adjust. Just read the direction a couple of times. HA HA.
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline   Reply With Quote
Old 01-24-2013, 09:33 PM   #5
Jr1 I have the same identical problem on bedroom slide on a 2008 wildcat 30 lsbs fith wheel. Leaks on left side of bed at bottom seal did leak on both side but got on e side fixed
yazookid1987 is offline   Reply With Quote
bed, bedroom slide
