Old 07-30-2016, 03:13 PM   #11
Fuses
Originally Posted by wmmhvac View Post
I did check the battery disconnect switch and it is pulled out or on. Thanks for your reply
There is probably a separate fuse for your slide outs under the camper. Same thing happened to me...fuses in the box were good, but under the camper was bad. Mine was located under the camper near the front on the right side as I looked at the hitch. There could be wires under there with a small rubber box attached ...pull the box apart and replace the fuse.
podfamily is offline   Reply With Quote
Old 07-30-2016, 03:38 PM   #12
Smile
Thank you all for your responses, there was a reset able breaker up by the battery, it was tripped reset it all ok now. Thanks again everyone for you help
wmmhvac is offline   Reply With Quote
Old 07-30-2016, 04:06 PM   #13
Ford Idaho's Avatar
Like this one?
Glad you worked it out and thanks for posting the fix..
Ford Idaho is online now   Reply With Quote
Old 07-30-2016, 04:09 PM   #14
yes just like that one again thanks everyone.
Old 07-30-2016, 05:05 PM   #15
I have an 8289. When I left home all slides came in. When I got to destination, all slides except dining slide worked fine. It didn't move though motor runs. Crank turns but nothing moves. Glad it wasn't the refrigerator slide!
robertew is offline   Reply With Quote
Old 07-30-2016, 05:21 PM   #16
CANADA FROG RALLY 2017
B and B's Avatar
A shear pin has broken somewhere with he drive system if both do not work.
B and B
2013 Rockwood 8289 Diamond Edition
GY D's/2.5 inch lift kit/Powerhouse 4 KW EFI Generator
2016 Ford F 350 Lariat Power Stroke Diesel Crew Cab FX4
2008 Golden Falcon 380PA Park Model Model
"Oh Canada,True North Strong and Free!"
slide, slide out
