Old 07-29-2016, 09:18 PM   #1
All 3 slides quit working
Hello,
I have a 2 week old rockwood signature ultra light 5th wheel and all 3 of my slides do not work it is the 8281ws. I checked fuses and breaker all ok but still the slides do not work any ideas
wmmhvac is offline   Reply With Quote
Old 07-29-2016, 10:18 PM   #2
jheacox1's Avatar
Originally Posted by wmmhvac View Post
Hello,
I have the same 5er. Haven't had an issue with the slides yet (knock on wood). Have you checked your battery disconnect switch located behind the battery box (on mine anyway)? I'm not sure if they'll operate if it's turned off (pushed in on mine) even if you're plugged in. Maybe that's the issue.
2015 Rockwood Signature Ultra Lite 8281WS
2015 F250 Crew Cab
jheacox1 is online now   Reply With Quote
Old 07-29-2016, 10:28 PM   #3
I did check the battery disconnect switch and it is pulled out or on. Thanks for your reply
Old 07-29-2016, 10:42 PM   #4
Brother Les's Avatar
Are your batteries 'up' to full power and do you keep your unit plugged in when not in use or do you have your battery disconnected when not in use? There are parasite losses from your battery from several places. Do your 'lights' work? You will need a full battery to move your slides.
Brother Les
Old 07-29-2016, 10:44 PM   #5
Hello,
Hydraulic or electric slides?
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 07-29-2016, 10:45 PM   #6
electric
Old 07-29-2016, 10:53 PM   #7
The Batteries are fully charged and i do keep unit plugged in when not in use. Everything else seems to work, I have not checked appliances. If unit is not plugged in i turn off battery switch. Thanks
Old 07-29-2016, 10:56 PM   #8
I dint have a 5th wheel but had the same issue last week with our slide. It was a fuse located on a wire between the battery & the frame. Maybe you have one outside that you've missed?
2016 Rockwood 2504S
Doxies in the Rockies is offline   Reply With Quote
Old 07-30-2016, 12:05 PM   #9
Remote system control board is separate from fuse/breaker panel and it has fuses also
Sasnett1 is offline   Reply With Quote
Old 07-30-2016, 12:39 PM   #10
TexasRVer53's Avatar
My TT had the same problem. There are 30amp fuses under the tongue between the battery and the frame. Both were bad.
TexasRVer53 is offline   Reply With Quote
slide, slide out
