Old 10-19-2014, 08:30 PM   #1
Jeanny's Avatar
Another Slide Out problem.
Wondering if some of you nice people have some ideas on why we could not get our Slides to retract.
We have a 2012 Sandpiper 330 RL. Checked Fuses! Batterie is charged! Solenoid is making a clicking sound but that's it.
Any ideas or suggestions greatly appreciated!
Jeanny is offline   Reply With Quote
Old 10-20-2014, 12:05 PM   #2
Jerry01's Avatar
My first thought would be an electrical connection. Check all of your connections, especially at the slide out motor itself. It takes a lot of current to move the slides, and if there is any corrosion on the cables, that would probably be your problem. I had the same issue on our last trailer. The slide out motor would only make a clicking sound. After cleaning the connections, everything worked fine. Jerry.
2005 GMC Sierra 2500HD, Duramax CC/SB
2022 Rockwood 2613 BS
Jerry01 is offline   Reply With Quote
Old 10-20-2014, 03:39 PM   #3
Jeanny's Avatar
Thank you Jerry!
We had to leave and return home so It may be a week or so before we get back to the Camper.
Fingers crossed that your answer will work.
Old 10-20-2014, 03:43 PM   #4
Should be a way to manually operate them, as well. You can at least get the trailer home, to work on it that way.
katkt is offline   Reply With Quote
Old 10-20-2014, 09:49 PM   #5
Jeanny's Avatar
katkt, Thank you for reading my post!
We have our Camper parked at a year round location at Ft Randall Dam in SD so it is not critical that we get the Slides in to take it home. I would just prefer to get the problem fixed. Not crazy about leaving them out all winter long!
It's about a 4 hr drive from our home in Omaha so I am trying to find out all the different possibilities that could be wrong before we head back up.
Been lurking on here a lot.....also see where a lot of people comment on there being a reset button somewhere between motor and solenoid ......I called Lippert ....and they confirm that there in fact is on our unit BUT they could not tell me exactly where I can find this.....only that it is a black reset button...hmmmm. Maybe someone will come along on here and can give me a little more specific answer.... Thank you much for your input!
slide, slide out
