Old 06-07-2018, 06:15 PM   #1
Are new Schwintek slide systems any more reliable?
Just curious how reliable these systems are now after being out for a number of years now. Was it the older ones that caused so much trouble? Are the new ones just as problematic? Has anyone had good luck with these? All I seem to read is how horrible they are. I have one in my new Cruise Lite and it makes me a little nervous.
Jmac1 is offline   Reply With Quote
Old 06-07-2018, 06:25 PM   #2
Keep your battery charged,Read the Manual,Run it ALL THE WAY OUT and ALL the WAY IN,DON"T "PLAY with IT"! Prayer Helps also! Youroo!!
Old 06-07-2018, 06:48 PM   #3
I have had no problems with mine over 3 seasons. And I don't "run all the way out/all the way in."
You should find your control box, though. It could be anywhere. Mine is behind a "door" with 3 hinges, 2 on one side and 1 on the other. You have to unscrew the single hinge and open the door. Looks like this:
Here's the controller:
Name:	Slideout control.jpg
If you do ever have to close it manually, you have to remove the motors. Here's a video:
I've attached a number of Schwintek guides for your use.
As I said, I've had NO issues.
2011 Traverse LT, 3.6L, FWD
Old 06-07-2018, 06:59 PM   #4
Thanks a ton for that info! Leaving in a week on a trip 1200 miles from home so that gives me some piece of mind.
Old 06-07-2018, 08:37 PM   #5
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
We have 2 slideouts with the 'Schwintek in wall' system, no problems so far but the exposed racks prevent the rubber seals from forming a tight seal. Water can get pushed along the racks and past the seals in heavy rain with strong wind, run down into a small gutter inside the wall and then drain outside. The system works but I wouldn't call it perfect.
Here is a link to a video that explains how to lubricate the mechanism.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 06-08-2018, 09:43 PM   #6
Have a one year old Rig with two Schwintek's in the front.. the slides operate normally but the controllers are buggy and throw codes. One side throws a code when its slide is in...the other when its slide is out.
The Lieutenant is offline   Reply With Quote
Old 06-08-2018, 09:49 PM   #7
Have you tried re-synchronizing?
Old 06-08-2018, 10:49 PM   #8
From what I can tell they are synced. Both are throwing a #9 motor short code but that should not be letting the slides operate. I read in their troubleshooting paperwork that the system needs to be re-energized but it does not tell how to do that.
Old 06-08-2018, 11:36 PM   #9
Assuming that by "#9" you mean "9 blinks," the third doc I posted in post #3 says #9 is a "Hall short to ground," and says, "Consult Tech Service and Manual (574) 537-8900 Or Email for Support warranty@lci1.com"
It says Motor Short is 6 blinks, not 9.
Someone posted how to replace the Hall sensors, vice the whole motor:
schwintek slide motor repair
slide
