Old 03-31-2018, 02:41 PM   #1
back slide goes out 1/3
I have a 2017 Coachmen Leprechaun and the bedroom slide just started going out 1/3 of the way. The motor just stops.
WTUSSSA is offline   Reply With Quote
Old 03-31-2018, 03:18 PM   #2
Battery fully charged PLUS connected to shore power? Did you check it to be sure it is a good battery?
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 03-31-2018, 04:14 PM   #3
I am on shore power but not sure about the batteries. Could it be a fuse? I did not check. I thought something is blocking it but can't see where.
Old 03-31-2018, 07:05 PM   #4
Could be a fuse or switch, but sounds like weak battery. Got jumper cables? Jump the battery off your truck.
Old 04-05-2018, 01:00 PM   #5
I followed the instructions to reset the motor controller on our slide out and then it would go all the way out and all the way in. I talked with a tech and he said never let go of the button until the slide is all the way out or all the way in, it tends to get the two motors out of sync and then it will stop because the slide is crooked. Just FYI, I hope you got it done.
CA2FL is offline   Reply With Quote
slide
