Old 11-18-2018, 11:20 PM   #21
Yes the slide is a bed slide
Jimbone is offline   Reply With Quote
Old 11-18-2018, 11:28 PM   #22
2007 WildCat 32QBBS
18CrewDually's Avatar
Did you look on the top of the slide from inside the bedroom? Maybe a gasket/seal popped off and is trapped between the wall and slide trim, stopping the top from going out all the way.
18CrewDually is offline   Reply With Quote
Old 11-19-2018, 08:24 AM   #23
On my 5th wheel, the top stops first then the bottom stops a few seconds later. Watch one of your other slides and see if they do that also.
Old 11-19-2018, 08:55 AM   #24
New to FR. Old to TT
Originally Posted by Jimbone View Post
Yes I do have slide topper I tried turning topper and it turn and it got loose and slide did not move going to take it off just to be sure it's not the problem thanks for the ideal
If you are able to, try to push the inside top of the slide while some one pushes the open switch. If you can move the top somewhat mere then what it has been opening then something is out of alignment, if it won't go out any more than something is stopping the top of the slide. As said above look at the slide roof when slide is mostly in to see if something is stuck to the back side of inside seal.
2018 GMC 2500 Denali HD ,Duramax with Allison trans.
2019 Cedar Creek 36ck2
Tall frog is offline   Reply With Quote
Old 11-19-2018, 09:43 AM   #25
Want to thank everyone for the help I've talk to a rv technician and he coming out to day to check it out he said that some time you have to just shove the top out to get it realined so he going to check it and make sure with all the adjustment I tried that there right .
So thanks again for all the help I'll let you know what happens
slide
